Relay for on/off Actuated water Valve
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139821
Printed Date: May 02, 2024 at 4:18 PM
Topic: Relay for on/off Actuated water Valve
Posted By: abelaguilar
Subject: Relay for on/off Actuated water Valve
Date Posted: December 01, 2015 at 3:04 PM
Hello: I have a 120 V on / off electric actuator valve from valworx.com. I have been able to wire it with a 3 way switch meaning when power is sent to the (open valve) circuit, it opens and when power is sent to the (close valve), it closes.
However, I wanted to use a zwave 3-way switch to automate this process and I have not been able to make a zwave 3 way switch behave in the same manner as a conventional 3 way switch. Something about how these z wave 3-way switches are wired that makes them different.
Can someone help me figure out how to use a spdt relay to make this happen? I understand the basics and believe that a spdt relay will allow me to switch power between the open and close circuits on this valve.
Date Posted: December 01, 2015 at 3:07 PM
Sorry i posted this in the wrong forum.
