Off the Shelf Latching Exist?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144093
Printed Date: May 15, 2024 at 4:42 PM
Topic: Off the Shelf Latching Exist?
Posted By: tiedye1604
Subject: Off the Shelf Latching Exist?
Date Posted: January 29, 2018 at 7:39 PM
Im working on a keyless ignition for a sportster.
I have figured out how to make the system work using 3 spdt relays.
Space is my issue. Between the controller, the relays, and my keyed ignition cylinder(have to keep it for current resistance), and all the wireing. I dont have the room to hide it in the space i have.
Is there a relay i can buy, that will latch on with channel A negitive pulse, and then unlatch/reset with channel B negative pulse? My current draw is a maximum of .04amps, just has to be able to take some vibrations, it is on a harley after all.
Posted By: Ween
Date Posted: January 29, 2018 at 10:03 PM
file:///C:/Users/user/Downloads/fb%204rc933364027%20(1).PDF
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=V23145-X0000-A002&DocType=DS&DocLang=EN
https://www.delcity.net/store/Latching-Relays/p_818110.h_818111
https://www.gmpartsgiant.com/parts/chevrolet-relay~13500116.html
The last listing above is a relay GM uses in many of their newer vehicles. Ebay search of a Corvette fusebox will get you that relay, plus a few others, fuses too. All for less than the GM retail price.
Date Posted: January 31, 2018 at 9:16 AM
Thank you, after a little more seaching, I found a 4-channel 12v relay module 1/3 of the size of all my relays and much cleaner wiring.
Posted By: howie ll
Date Posted: February 03, 2018 at 10:08 AM
Can you please give a link to the above relay, also look for Omron dual coil latching relays.
Can you please show us a diagram for your keyless IGN?
