451 specific function
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19177
Printed Date: May 18, 2024 at 12:40 AM
Topic: 451 specific function
Posted By: xxmattfxx
Subject: 451 specific function
Date Posted: September 22, 2003 at 6:05 PM
I've done some testing and found out that with the 451 I need it to pulse negative on the blue wire for the unlock, and pulse negative on the green wire for lock. Could someone tell me how to wire the 451 to serve this function?
Posted By: auex
Date Posted: September 22, 2003 at 9:32 PM
I assume you are talking about the dei door lock relay module, 451M. If you are not plugging it into a dei alarm, then you can wire the pulses whatever way you wanted to, then you wire the red wire the opposite of the alarm's output. If you have negative output for locks then you would wire the red as +12V. As far as wiring what else are you looking for?
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: September 22, 2003 at 10:31 PM
I am wiring it into a dei alarm, I have central door locks the blue come off of the brown wire for the locks and the green comes off the white. and each of those wires activates with a negative pulse.
Posted By: auex
Date Posted: September 23, 2003 at 6:19 PM
Then plug the three pin harness into the alarm, then wire the purple wire to ground, then hook the blue to the unlock and green to the lock of the central locking system.
Date Posted: September 23, 2003 at 7:14 PM
I"ve hooked it up, the keyless locks work fine other than the blue and green had to be switched, but the problem is that now the regular operation of the door locks do not work. They are cental door locks, when one is locked/unlocked the other does the same. would placing diodes on the blue and green wires solve this? if so what amp diode?
Posted By: auex
Date Posted: September 23, 2003 at 9:59 PM
Diode may work, I would try a 1 amp and work my way up.
