relay help...on ignition coil
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20909
Printed Date: March 21, 2026 at 7:32 AM
Topic: relay help...on ignition coil
Posted By: mtimmy
Subject: relay help...on ignition coil
Date Posted: November 02, 2003 at 8:24 PM
Hi,. I have an art project that I needed to shot some flame ......
I have a spark plug connected to a standard car ignition coil,. I have a ballast resistor to keep the current down also.... here comes to my problem...
I needed to use a SPDT relay to control the ignition coil so that it sparks couple times per second but not continous spark.... What should I do in order to achieve this goal?...
I have found a wiring diagram of connecting a capacitor's
- to 85
+ to 30 (with together the 12V supply )
and wired 85 and 85A together and grounded the 86
I can't make the relay to work... any help?
thanks
Posted By: auex
Date Posted: November 02, 2003 at 8:36 PM
86 needs to be a positive trigger of some sorts. If both 85 and 86 are ground then the relay never energizes. Here is the way it should be. 85 ground, 86 switched +12V, 30 +12V, 87 Output.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
