12 volt LED blink w/ alarm
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47274
Printed Date: May 28, 2024 at 1:51 PM
Topic: 12 volt LED blink w/ alarm
Posted By: DanNEBTD
Subject: 12 volt LED blink w/ alarm
Date Posted: January 09, 2005 at 12:15 PM
i now have three 12 volt leds and am trying to figure out ho to make them blink using the alarm LED wire. only problem is it's the neg that changes and i dont know how to make a relay setup that changes grounds. plz help.
Posted By: auex
Date Posted: January 09, 2005 at 6:34 PM
Won't work. Most alarm led outputs are 2 volts. You can however go buy 3 2V leds from rat shack, wire them in series, connect the + and - to the led output, and they will blink the way the alarm will.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: JGREENSTREAK
Date Posted: January 21, 2005 at 11:52 PM
hea man, anybody who tells someone that something is not possible is wrong. what you are trying to do is very possible, all you have to do it connect the positive side of the led to a constant 12volts and then the negative side of the led to the negative side output from the alarms led output. i did this before and had problems with it because i thought that you had to use a relay, well you do not need the relay in this case. i hooked up five leds to my alarm and no problems ever occured. let me know if this works for you or you have any other questions. JGreenStreak@aol.com
