wiring Relays and diodes
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52582
Printed Date: February 01, 2026 at 9:46 AM
Topic: wiring Relays and diodes
Posted By: domas
Subject: wiring Relays and diodes
Date Posted: March 25, 2005 at 6:02 PM
Can anybody help me wire  2 relays , 2 diodes , switch 0n-0ff-on  and 1 motor so that  when switch in ON position motor rotates in  direction A and when switch in other ON position motor rotates in  dirrection B. Relays have to be wired the same way, and not using 87A, and 30, 85 to ground. 2diodes have to used.
questioner
Posted By: auex
Date Posted: March 25, 2005 at 6:36 PM
Why so many specifics? Also not using 87A you can't do a reverse polarity relay system. I say you are screwed unless the motor is self grounding. Also technically if the relays have to be wired the same way it won't work regardless because they will go to the same wires.
Why do I smell homework?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: domas
Date Posted: March 25, 2005 at 8:18 PM
thank you, auex, anyway
well, it's my small project.  i think it's possilble, by using 2 diodes. Now i'm trying to find out. If i get an answer i'll let yuo know.
questioner
Posted By: auex
Date Posted: March 25, 2005 at 8:48 PM
Is there any reason why you can't use 87A?
Posted By: domas
Date Posted: March 26, 2005 at 8:51 AM
I know that there's 2 ways actually you can do that , but i just wanna find out how to do with 2 diodes. But if i don't figure it out i'll always can use 87A. Thanks, it were just only  you who responded to my question.
questioner
Posted By: ff-mike
Date Posted: March 30, 2005 at 12:36 PM
Why don't you just use a DP-DT-CO switch and screw the rest?
