relay to get 12 v to starter
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61408
Printed Date: February 25, 2026 at 8:00 AM
Topic: relay to get 12 v to starter
Posted By: sac surfer
Subject: relay to get 12 v to starter
Date Posted: August 16, 2005 at 12:32 AM
I am only getting 6 volts to my starter on my 66 chevelle and it is not enough to activate the solinoid so I would like to install a relay to take 12 volts directly from the positive post of the battery to the starter when I turn the ignition switch over. The relay (30 amp)has 4 posts numbered 30  87  85  and 86. Which wires connect to which number to achieve this?
sacsurfer
Posted By: Velocity Motors
Date Posted: August 16, 2005 at 8:11 AM
Use this relay diagram : https://www.velocitymotorsport.com/images/install_notes/P2P.jpg
