Latching Relay?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72501
Printed Date: May 06, 2024 at 9:03 AM
Topic: Latching Relay?
Posted By: nitrous
Subject: Latching Relay?
Date Posted: February 09, 2006 at 10:48 AM
This is my first post and need help from the pros.  Not very good with electrical systems.
I am using a momentary switch for nitrous activation.  I need it so I can push the button and have the system stay on, until the ground is cut via a wide open throttle switch.  The the thing i don't understand is how to make the latching relay reset it's self after it completes a cycle.  I need it to reset it's self, so when I go back to full throttle the nitrous will not re-activate.  So it requires pushing the button again to activate.
Any schematics or list of parts would be awesome.  Thanks
Posted By: infinkc
Date Posted: February 09, 2006 at 9:29 PM
posted_image
you will need one more relay hooked to your open throttle switch, so when it is triggered it will send a pulse back to the momentary switch to disengage the latching. you will also need it to cut the signal off so the open throttle switch doesnt keep activating the latched relay as well.
There are 10 types of people in the world, ones that understand binary and ones that dont.
Posted By: hotwaterwizard
Date Posted: February 09, 2006 at 11:50 PM
When power is dropped the relay resets it's self automaticly.
just hook the ground where you hook the ground  that is cut by the throttle switch.
posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Posted By: sane
Date Posted: March 06, 2006 at 12:35 PM
does anyone have a schematic diagram of a remote start  module with about 3to 6 relays with diodes
