closed loop to normal open transistor
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78736
Printed Date: May 15, 2026 at 2:16 AM
Topic: closed loop to normal open transistor
Posted By: shaun gale
Subject: closed loop to normal open transistor
Date Posted: June 05, 2006 at 6:15 AM
hi i know this circuit circuit exists because i have used it before but i cant rember the values . i want to use the rear heated window element (closed loop ) to trigger an alarm with only n/o to ground inputs .i dont want to use a relay because of  the current  draw . i think the circuit i usedto had a tip 41c transister and adrop down resister .
thanks for your time
Posted By: hotwaterwizard
Date Posted: June 09, 2006 at 10:33 PM
posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Date Posted: June 09, 2006 at 10:36 PM
You can use a TIP41 for the NPN but it only handles 6 amps with a heat sink the 2N2055 handles 15 Amps of current.
Stockton California
Posted By: shaunshow
Date Posted: June 10, 2006 at 4:42 PM
thanks for that . that should do the trick cheers
