Two trigger relay setup for led markers
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80064
Printed Date: May 10, 2024 at 10:03 AM
Topic: Two trigger relay setup for led markers
Posted By: cliff96
Subject: Two trigger relay setup for led markers
Date Posted: July 08, 2006 at 4:11 PM
So I understand the basic concept of relays, but getting my head around the (1st and preferable scenario) is a bit hard for me. Vehicle 96 neon, led tails and corners (in stock housings) with incandecent front turn signals. Modified flasher to elimate the "fast blinking"
Inputs:
Running lights (on with headlights)
Turn signal lamp
Controlled (output) light: Corner marker(s)
Desired operational characteristics of corner marker scenario 1:
-running lights on, the corner marker is on
   -when the turn signal is on the corner marker turns off (opposite of turn signal lamp)
-running lights off, corner marker is off
   -corner marker flashes with turn signal
Desired operational characteristics of corner marker scenario 2 (seems like it would be easier):
   -does not flash with turn signal
I think I have this one figured out see pic:
posted_image
'96 Plymouth neon
Posted By: Hoptup32
Date Posted: July 09, 2006 at 7:48 PM
Forget about using relays, read the information on the site below to have the side markers function as running lights and flash alternately with the turn signals.
https://danielsternlighting.com/tech/markerflash/markerflash.html
Posted By: cliff96
Date Posted: July 10, 2006 at 9:18 AM
thanks for the reply Hoptup32. That's exactly what I want them to do and it's a lot less complicated to impliment.
Much thanks
'96 Plymouth neon
