GM double heater systems diagram
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89479
Printed Date: June 08, 2024 at 8:44 AM
Topic: GM double heater systems diagram
Posted By: graymae
Subject: GM double heater systems diagram
Date Posted: January 24, 2007 at 1:07 PM
I have a 2003 olds sihoutte and i have installed a crimestopper rs-1300dp. In the installation manual it says to use a relay for heavy duty/high current ignition circuits greater than 30amps, dual ac, industrial vehicles, etc. they did not give any diagrams on how to do this, does anyone know how to hook this up using a relay? Any sugessions would be greatly appreciated. thanks
Posted By: graymae
Date Posted: January 24, 2007 at 4:45 PM
i found a diagram showing pin 86 and 30 connected to the battery with a 30amp fuse, 87 to the acc wire and 85 to ign3 output. there is no ign3 in the vehicle and there is no ign3 output on the remote start. is there another way to wire this? do i have to make an ign3 out? if so, how do i do this? thank you.
