2001 ford escape 6 speaker plus sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100207
Printed Date: May 12, 2024 at 6:27 PM
Topic: 2001 ford escape 6 speaker plus sub
Posted By: snubby2
Subject: 2001 ford escape 6 speaker plus sub
Date Posted: December 18, 2007 at 9:59 PM
Want to install a pioneer deck that I have in place of the factory 6 disc changer that no longer functions. What all do I need other than the install kit and wire harness? I am guessing I will need something to be able to hook up to the amp so that the sub works correctly even though the pioneer deck has and amp itself.
Also, are there any other hidden secrets that I need to know about?
Posted By: kylecm85
Date Posted: December 18, 2007 at 10:58 PM
hey i checked and they make an amp intergration harness the metra part number is met70-5516 this should help you out and the radio harness is met 70-1771 this should alow you to keep the factory amp.
Posted By: snubby2
Date Posted: December 19, 2007 at 7:16 PM
OK thanks...I saw that too, just wanted to make sure that was the thing to do. Was afraid I would be pushing to much from the pioneer deck (50 x 4 Mosfet) into the factory amp where it would cause either complications or malfunctions.
Posted By: kylecm85
Date Posted: December 19, 2007 at 8:50 PM
you should not have any problems if u think about it u are just powering the factory anp and supplying signal to it. So it should not mess with the internal amp on the pioneer. I have a ford system with the jbl 8 speaker system and never had a problem using aftermarket deck.
Posted By: snubby2
Date Posted: December 19, 2007 at 10:01 PM
very good...all i have to get now is the amp integration harness and i am set...thanks for the input.
Posted By: kylecm85
Date Posted: December 19, 2007 at 10:41 PM
no problem if u need anything else give me a shout
Posted By: snubby2
Date Posted: December 23, 2007 at 6:26 PM
Just found a better option for use on Pioneer decks which usually have 2 RCA outs. Use the Metra 70-5519(has 2 male RCAs instead of just 1 like on the metra 70-5516), that way you don't need to get an additional y-cable.
