2004 range rover, remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101468
Printed Date: June 01, 2024 at 11:39 AM
Topic: 2004 range rover, remote start wiring
Posted By: northern
Subject: 2004 range rover, remote start wiring
Date Posted: January 22, 2008 at 4:13 PM
2004 Land Rover Range rover wiring information request please.
looking at doing a remote start, I have a few extra keys so I don't mind using a key wrap or universal bypass kit.
Posted By: KarTuneMan
Date Posted: January 24, 2008 at 10:04 AM
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES | 12 VOLTS | Red | Ignition switch harness | + | | | You must remove portions of the center console to access the ignition switch. |
| IGNITION | Green (large gauge) | Ignition switch harness | + | | | You must remove portions of the center console to access the ignition switch. |
| IGNITION 2 | Green (small gauge) | Ignition switch harness | + | | | You must remove portions of the center console to access the ignition switch. |
| ACCESSORY | Violet/black | Ignition switch harness | + | | | This wire is actually a third ignition and must be connected as such or the vehicle will not start. You must remove portions of the center console to access the ignition switch. |
| STARTER | BLACK / YELLOW | Ignition switch harness | + | | | You must remove portions of the center console to access the ignition switch. |
| TACH SIGNAL | White | At 1st coil on driver's side of engine | AC | | | Under the engine's plastic cover. |
| LOCK | Blue/red | At module in driver's door | - | UNLOCK | WHITE/ black (double pulse) | At module in driver's door | - | DOORPIN | BROWN / white | Found at module in each door | - | HOODPIN | Violet/green | At pinswitch under hood on driver's side | - | TRUNK RELEASE | BROWN / gray | At release switch in dash | - | FACTORY ARM | Arms with lock wire | | | FACTORY DISARM | Disarms with unlock wire | | | BRAKESWITCH | BROWN / gray | At switch above brake pedal | + | | | You must test with ignition ON. |
| PARKLIGHTS | Black | SEE NOTES | | | | Use a relay to open this wire at the light switch. This will turn the lights on. See the appropriate TECH TIP diagram. |
| HORN | BROWN / red | At steering column | - |
Available Notes | PLEASE NOTE: This vehicle is equipped with a TRANSPONDER passive anti-theft system. Please refer to the appropriate security diagram before any remote starter installation. IMPORTANT NOTE FOR REMOTE START INSTALLATIONS: Once the vehicle has been started by remote, the ignition switch locks out and the key cannot be inserted. You must apply the brake to shut the vehicle down before the key will go in.
| | For remote start key sense must be energized using an accessory output. The trigger must drop out during crank to allow the key to turn in the ignition once the vehicle is remote started.
Posted By: northern
Date Posted: January 24, 2008 at 5:34 PM
What source did you use for this wiring? Thanks Kartune's!
