2007 Seat Leon Alarm Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103916
Printed Date: May 02, 2024 at 2:04 PM
Topic: 2007 Seat Leon Alarm Wiring
Posted By: petkyp
Subject: 2007 Seat Leon Alarm Wiring
Date Posted: April 12, 2008 at 6:28 AM
Hi,
I am looking for a wiring diagram for my seat leon 2007 make. I need it to install an alarm system with a remote starter.
Thank you very much!
Posted By: kola7126
Date Posted: April 12, 2008 at 5:08 PM
POWER SUPPLY + 30: connect to the 5 mm2 RED wire located in the fuse box.
- 31: connect with a ring terminal directly to the car body.
IGNITION WIRE +15/54: connect to the 4 mm2 BLACK wire located in a multiway
connector in the fuse box.
DIRECTION INDICATORS Connect to the BLACK/ WHITE and BLACK/ GREEN wires in the wiring
harness coming out of the brown connector placed behind the fuse box.
ELECTRIC WINDOWS Negative control signal
The closing of the electric windows is obtained timing to 24s the
YELLOW/LIGHT BLUE wire used for the closing of the doors.
CENTRAL DOORS LOCKING Negative control signal
Connect to the YELLOW/LIGHT BLUE wire (lock) and VIOLET
(YELLOW /GREEN) wire (unlock) located in the wiring harness directly
inside the driver’s side door.
IMMOBILISATION POINT 1 Gasoil pump
Cut the BLACK/ VIOLET wire located in the wiring harness coming out
of the 10 AMP fuse nr. 29, in the fuse box, placed on the left of the
dashboard, driver’s side.
STARTER CUT OFF + 50: Cut the RED / BLACK wire located at the position nr. 3, in the
wiring harness coming out of the 6 way light brown connector placed on
the connector holder plate, under the dashboard, driver’s side.
BONNET SWITCH Install an additional switch on the front headlamp support plate, driver’s
side.
DOORS SWITCH Connect to the PINK/LIGHT BLUE (BLUE/GREY) wire located at the
position nr. 16 of the light blue connector coming out of the control
system placed on the left of the steering column.
BOOT SWITCH Connect to the BROWN / BLACK wire located at the position nr. 15 of
the light blue connector coming out of the control system placed on the
X
Posted By: petkyp
Date Posted: April 16, 2008 at 2:23 PM
Thank you very much for this... Do you know if there is any other more detailed wiring info, like diagrams and so... ???
I could really use the help because I bought quite a complicated alarm system with remote starter (that needs immobiliser bypass also) etc..
Thank you!
