1995 isuzu rodeo wiring codes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1047
Printed Date: April 23, 2024 at 9:45 PM
Topic: 1995 isuzu rodeo wiring codes
Posted By: jacksonsfinest
Subject: 1995 isuzu rodeo wiring codes
Date Posted: May 30, 2002 at 8:45 PM
i need wiring codes for a basic alarm install with door locks.
this is for an install in the morning
thanks for any help!
box+woofer does not always equal bass!
Posted By: Velocity Motors
Date Posted: May 30, 2002 at 8:53 PM
Isuzu
Rodeo
1995
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE OR
BLACK/ RED - IGNITION SWITCH HARNESS
Ignition  #1:
BLACK / YELLOW
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
BLUE OR BLACK
Brake  Light:
RED
(+) AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLUE (2.6L) OR
BLACK/ RED (3.2L) SEE NOTES *
Parking Lights:
GREEN/ RED
(+) AT HEADLIGHT SW.OR DRIVER KICK
Headlights:
RED / BLUE (-)
AT HEADLIGHT SWITCH OR AT RELAY
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * 2.6L Engine BLUE Tach Wire Located On Passenger Side Of Engine Compartment (Single BLUE Wire With Female Bullet Terminal In Clear Insulator). 3.2L Engine BLACK/ RED Tach Wire Located At Black 6 Pin Plug On Electronic Ignition Module.
Isuzu
Rodeo
1995
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK
Starter  Kill:
BLACK/ WHITE OR
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
RED / GREEN OR BLACK (-)
2 WAY WHT CONN.BEHIND DRV FRT SPEAKER
OEM Horn:
BLACK/ ORANGE (-)
13 WAY WHITE CONN.ABOVE PARK BRAKE
Power  Lock:
ADD ACTUATOR
ADD ACTUATOR TO DRIVER DOOR **
Power  Unlock:
ADD ACTUATOR
Trunk  Release:
RED / BLUE (+)
AT TAILGATE GLASS RELEASE SWITCH
Alarm  Input Wire:
Notes:
* Need to Add Actuator for Door Lock D. 1995 1/2 Passport Door Locks: L GREEN/ RED (Lock) & RED / WHITE (Unlock) In Driver Kick Panel. Negative Pulse Door Lock
Isuzu
Rodeo
1995.5
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE OR
Ignition  #1:
BLACK / YELLOW
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
BLUE OR BLACK
Brake  Light:
RED
Tach  Signal:
BLUE (2.6L) OR
Parking Lights:
GREEN/ RED
Headlights:
RED / BLUE (-)
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * 2.6L Engine BLUE Tach Wire Located On Passenger Side Of Engine Compartment (Single BLUE Wire With Female Bullet Terminal In Clear Insulator). 3.2L Engine BLACK/ RED Tach Wire Located At Black 6 Pin Plug On Electronic Ignition Module On Passenger Side Of Vehcile.
Isuzu
Rodeo
1995.5
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK
Starter  Kill:
BLACK/ WHITE OR
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
OEM Horn:
BLACK/ ORANGE (-)
Power  Lock:
ADD ACTUATOR
SEE NOTE BELOW **
Power  Unlock:
ADD ACTUATOR
SEE NOTE BELOW **
Trunk  Release:
RED / BLUE (+)
Alarm  Input Wire:
Notes:
** Early 1995 Models Require An Actuator  . 1995 1/2 Passport Door Locks: L GREEN/ RED (Lock) & RED / WHITE (Unlock) In Driver Kick Panel. Negative Pulse Door Lock .
I have listed both the 1995 and 1995 1/2 diagrams for you. Not much difference but they were both on file so I thought that you may want both seeing that you didn't specify whcih one you were working on.Good luck !!
Date Posted: May 30, 2002 at 10:23 PM
hey man , thanks you really saved me alot of time!!!
respect.
