08 Nissan Xterra Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107929
Printed Date: May 05, 2024 at 5:38 AM
Topic: 08 Nissan Xterra Alarm/Remote Start Wiring
Posted By: chiarlanza
Subject: 08 Nissan Xterra Alarm/Remote Start Wiring
Date Posted: October 04, 2008 at 8:57 PM
Looking for Starter / Alarm and Cruise Info for an 08 Nissan Xterra,
Posted By: i am an idiot
Date Posted: October 04, 2008 at 9:03 PM
2007-2015 Nissan Xterra
Battery GREEN (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE/ GREEN (+) IGNITION SWITCH HARNESS
Starter 1 GRAY (+) IGNITION SWITCH HARNESS
All Door Trigger BROWN (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
Domelight Super BROWN (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
LF Latch GRAY (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
RF Latch LIGHT GREEN (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
LR Latch PINK (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
RR Latch BLUE (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
Trunk Trigger YELLOW (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
Alarm Disarm GRAY (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
Alarm Arm LIGHT BLUE (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
Parking Lights GRAY (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
To avoid domelight delay, catch individual door triggers and diode isolate
Accessory 1 RED (+) IGNITION SWITCH HARNESS
Accessory 2 GREEN/ YELLOW (+) IGNITION SWITCH HARNESS
Starter 2 LIGHT GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type NISSAN NVIS® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLACK (+) IGNITION SWITCH HARNESS
Tachometer LIGHT BLUE (AC) AT ECM MODULE ON PASSENGER FENDER
Speed Sense LIGHT BLUE (AC) IN HARNESS TO GAUGES
Brake Lights YELLOW (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights LIGHT BLUE (+) IN HARNESS IN DRIVERS KICKPANEL TO REAR
Horn BROWN (-) IN HARNESS AT STEERING COLUMN
Alarm Indicator GREEN (-) AT BCM MODULE UNDER DRIVER SIDE DASH TO RIGHT OF STEERING COLUMN
Posted By: purevision
Date Posted: January 13, 2010 at 5:45 PM
Anything on the door lock wires?
Posted By: 315customs
Date Posted: December 07, 2010 at 8:32 AM
Can anyone tell me what the note is for the Speed Sense wire?
