2007 ford taurus, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109476
Printed Date: April 19, 2024 at 1:02 PM
Topic: 2007 ford taurus, remote start
Posted By: jnjm2003
Subject: 2007 ford taurus, remote start
Date Posted: December 04, 2008 at 7:48 PM
Need remote start information on 2007 Ford Taurus.
Posted By: ckeeler
Date Posted: December 05, 2008 at 8:23 PM
12 VOLT CONSTANT | LIGHT GREEN/ PURPLE (+) | IGNITION SWITCH HARNESS | | STARTER | RED / LIGHT BLUE (+) | IGNITION SWITCH HARNESS | | STARTER 2 | N/A | | | IGNITION 1 | RED / LIGHT GREEN (+) | IGNITION SWITCH HARNESS | | IGNITION 2 | BLACK/ LIGHT GREEN (+) | IGNITION SWITCH HARNESS | | IGNITION 3 | N/A | | | ACCESSORY /HEATER BLOWER 1 | GRAY / YELLOW (+) | IGNITION SWITCH HARNESS | | ACCESSORY /HEATER BLOWER 2 | N/A | | | KEYSENSE | N/A | | | PARKING LIGHTS ( - ) | N/A | | | PARKING LIGHTS ( + ) | BROWN (+) | @ SJB, BOTTOM Plug, Pin 31, See NOTE *1 | | POWER LOCK | PINK / YELLOW (TYPE B) | @ GEM. 26-Pin Plug, Pin 18, See NOTE *1 | | POWER UNLOCK | PINK/LIGHT GREEN (TYPE B) | @ GEM, 26-Pin Plug, Pin 6, See NOTE *1 | | LOCK MOTOR WIRE | PINK/BLACK (+) | @ SJB, TOP Plug, Pin 3, See NOTE *1 | | DOOR TRIGGER | See NOTE *2 | @ GEM, See NOTE *1 | | DOMELIGHT SUPERVISION | BLACK/ LIGHT BLUE (+) | @ SJB, TOP Plug, Pin 22, See NOTE *1 | | TRUNK RELEASE | PURPLE / YELLOW (-) | @ GEM, 26 Pin Plug, Pin 3, See NOTE *3 | | SLIDING POWER DOOR | N/A | | | HORN | DARK BLUE (-) | @ SJB, BOTTOM Plug, Pin 1, See NOTE *1 | | TACH | Any wire that is NOT RED | @ any IGNITON COIL or FUEL INJECTORS | | WAIT TO START LIGHT | N/A | | | BRAKE | RED / LIGHT GREEN (+) | @ SWITCH ABOVE BRAKE PEDAL | | FACTORY ALARM DISARM | PINK/WHITE | @ GEM, 26-Pin Plug, Pin 4, See NOTE *1 | | ANTI-THEFT | FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM | TRANSPONDER @ IGNITION SWITCH TUMBLER | |
NOTES | NOTE *1 The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) located to the LEFT of the STEERING COLUMN. the SJB HAS (3) Plugs all are on the BOTTOM.
NOTE *2 these wires are at the 26-Pin Plug at the GEM, this vehicle has 4 door pin triggers, the DRIVERS DOOR is a YELLOW/BLACK (-) Pin 5, PASSENGER DOOR is a GRAY/RED (-) Pin 19 DRIVERS REAR DOOR is a LIGHT GREEN/ YELLOW (-) Pin 20 and the PASSENGER REAR DOOR is a PINK/LIGHT BLUE (-) Pin 7. When connecting to an ALARM SYSTEM, use all 4 DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM.
NOTE *3 On vehicles WITH a FACTORY KEYLESS ENTRY the TRUNK RELEASE wire is a PURPLE / YELLOW (-) on vehicle WITHOUT a FACTORY KEYLESS ENTRY, it is a GRAY/RED (+) at the Trunk Release switch. On Station Wagons to release the rear hatch, use the YELLOW/LIGHT GREEN (-) wire in the 26-Pin Plug of the GEM.
