2007 pontiac g6 gt remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110033
Printed Date: April 28, 2024 at 7:22 PM
Topic: 2007 pontiac g6 gt remote starter
Posted By: puffy929
Subject: 2007 pontiac g6 gt remote starter
Date Posted: December 25, 2008 at 10:56 AM
Anyone got the wiring diagram and what will I need to hook up everything. I.E. relays. power locks. Trunk release. rear defroster. I have the clifford matrix rs1.1 with the security bypass module. Thanks ahead of time .
Posted By: puffy929
Date Posted: December 25, 2008 at 8:14 PM
anything????
Posted By: oneohm
Date Posted: January 04, 2009 at 9:50 PM
12volts | RED / black (50A) | + | BCM, C3, pin D1 | Starter | yellow or PURPLE / white (not for remote start) | -,+ | PCM, blue plug, pin 23 or 26 |
| Ignition | pink | + | ignition harness or BCM, C4, pin D3 | Power Lock | white | - | driver kick or BCM, C1, pin 66 | Power Unlock | same as power lock wire | -1.5K ohms | | Lock Motor | gray/black to gray | 5 wire | driver kick or BCM, C3, pin A5 | Unlock Motor | tan | 5 wire | driver kick or BCM, C3, pin B1 | Disarm Defeat | tan | 5 wire | passenger kick or BCM, C3, pin A2 | Parking Lights+ | brown | + | BCM, C3, pin A7 | Parking Lights- | BROWN / white | - | switch or BCM, C2, pin 5 | Hazards | white | - | switch or BCM, C2, pin 9 | Turn Signal(L) | lt. blue/white (F), yellow (R) | + | BCM, C1, pin 38 (F), C3, pin A9 (R) | Turn Signal(R) | dk. blue/white (F), dk. green (R) | + | BCM, C1, pin 56 (F), C3, pin A12 (R) | Door Trigger | gray/black | - | driver kick or BCM, C1, pin 51 | Dome Supervision | gray | - | BCM, C3, pin A10 | Trunk/Hatch Pin | ORANGE / black | - | BCM, C1, pin 18 | Hood Pin | pink/black | - | pin switch or BCM, C1, pin 69 | Trunk/Hatch Release | BROWN / white | - | driver kick or BCM, C1, pin 71 | Power Sliding Door | N/A | | | Factory Alarm Arm | factory remote only | | | Factory Alarm Disarm | factory remote only | | | Disarm No Unlock | with ignition and Passkey | | | Tachometer | NOT pink | ac | any fuel injector | Horn Trigger | tan | - | switch or BCM, C2, pin 14 | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. | It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug. |
