2001 Jeep Cherokee Sport, Alarm/RS Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1115
Printed Date: April 28, 2024 at 8:14 PM
Topic: 2001 Jeep Cherokee Sport, Alarm/RS Wiring
Posted By: awd_sr
Subject: 2001 Jeep Cherokee Sport, Alarm/RS Wiring
Date Posted: June 04, 2002 at 8:57 AM
Does anyone have the wiring diagram for a 2001 Jeep Cherokee sport? Were there any changes from 00, and are there any things to look out for? Thanks
Posted By: awd_sr
Date Posted: June 05, 2002 at 3:51 PM
Does anyone know if the 2000 diagram will work for the 2001? I appreciate the help.
Posted By: Velocity Motors
Date Posted: June 05, 2002 at 10:34 PM
No change between the 2000 and the 2001 for ALL Cherokee models. ------------- Jeff
Posted By: awd_sr
Date Posted: June 05, 2002 at 10:37 PM
thanks again Jeff, again, this site is great. You guys truly are a huge help to all levels of installers, hobbyist and pros. Take care
Date Posted: June 05, 2002 at 11:11 PM
Not a problem AWD_SR !! Here is the wire color codes for the Cherokee and I posted the Nissan one as well for you in the other post. If you have any problems just post your questions and one of the members will help you out, maybe even me Remote Starter Wiring Colors and Notes | Function | | | Vehicle Color | Location | Start: | | | YELLOW | IGNITION SWITCH HARNESS | Ignition #1: | | | D BLUE | IGNITION SWITCH HARNESS | Ignition #2: | | | BLACK/ ORANGE | IGNITION SWITCH HARNESS | Ignition #3: | | | N/A | | Accessory: | | | BLACK/ WHITE | IGNITION SWITCH HARNESS | Brake Light: | | | WHITE/ GREEN | AT SWITCH ABOVE BRAKE PEDAL | Tach Signal: | | | GRAY | AT COIL ON PASSENGER SIDE OF ENGINE | Parking Lights: | | | BLACK / YELLOW | AT HEADLIGHT SWITCH | Headlights: | | | LIGHT GREEN | AT HEADLIGHT SWITCH | OEM Alarm Disarm: | | | VIOLET / YELLOW (-) | DRIVER'S KICK PANEL | OEM Alarm Arm: | | | ARMS WHEN DOORS ARE | LOCKED WITH DR. DOOR OPEN | Diesel Glow Plug: | | | | | Clutch Bypass Wire: | | | | | Notes: | | |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | | Vehicle Color | Location | Constant +12 Volts: | | | RED OR PINK/BLACK | IGNITION SWITCH HARNESS | Starter Kill: | | | YELLOW | IGNITION SWITCH HARNESS | Ignition +12 Volts: | | | D BLUE | IGNITION SWITCH HARNESS | Dome Lights/Superv: | | | YELLOW (-) | AT ANY PIN SWITCH | OEM Horn: | | | BLACK/ RED (-) | STEERING COLUMN HARNESS | Power Lock: | | | ORANGE / VIOLET (+) | LOCATED IN DRIVER'S KICK PANEL * | Power Unlock: | | | PINK/VIOLET (+) | LOCATED IN DRIVER'S KICK PANEL * | Trunk Release: | | | PINK/BLACK (+) | (LIFTGATE UNLOCK) | Alarm Input Wire: | | | YELLOW (-) | AT ANY PIN SWITCH | Notes: | | * Positive Pulse Door Lock |
------------- Jeff
Posted By: awd_sr
Date Posted: June 06, 2002 at 6:12 AM
Thanks again Jeff, I tell you, you guys here at this site surely save people lots of time and wads of dough! I'll be sure to post my Q's here as I start 'er up. Take it e-z. Tony
Posted By: awd_sr
Date Posted: June 06, 2002 at 12:15 PM
I noticed that in the above wiring list, it says that the Power Lock and Unlock are "positive Pulse door lock", but the list I downloaded for the 2000 says 3 wire negative. Which one of these is true? Also, the 2000 list says "door unlock may require relay; for keyless entry upgrade to an alarm, Arm=Blue, Disarm=Blue/Red, located in overhead console." I'm about to install a Crim Guard 745i3 with built in relays for door lock/unlock, and according to their manual for 3 wire negative systems there is a blue wire from the alarm that goes to the swithc unlock wire, and a GREEN/ black wire that goes to the switch lock wire. Does arm mean lock and disarm mean unlock? Or do I hook these to the wires listed in the above list (blue from alarm to pink/violet in car & GREEN/ blk from alarm to ORANGE / violet of car) Thanks again
Posted By: awd_sr
Date Posted: June 10, 2002 at 6:11 AM
I wanted to thank you again. I completed the install this weekend, and it took me like 9 hours to get it all in (don't laugh)... I guess the more installs you do, the quicker you get. It was hard for me to solder under the dash because the factory wiring harness' have little to no slack. Then figuring out a place to put all the sensors was tough. Then trying to fit a drill under the dash to for grounding was another thing that slowed me down. But I love the new alarm and all the features. Thanks again Jeff!
Date Posted: June 10, 2002 at 5:47 PM
Good to hear another install went well. If you have any other questions you know where to post ------------- Jeff
