2009 Hyundai Santa Fe Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115455
Printed Date: May 01, 2024 at 8:16 PM
Topic: 2009 Hyundai Santa Fe Alarm/Remote Start Wiring
Posted By: sroake4
Subject: 2009 Hyundai Santa Fe Alarm/Remote Start Wiring
Date Posted: August 04, 2009 at 10:43 AM
Does anyone have Alarm remote start wiring information for the 2009 Santa Fe Thanks in advance. ------------- STEVER
Posted By: richl68
Date Posted: August 04, 2009 at 11:05 AM
gonne have to break it up into sections but here you go 12 Volts | red (40A) | + | ignition switch, 6 pin plug, pin 5 |
Second 12 Volts | pink (40A) | + | ignition switch, 6 pin plug, pin 2 |
Starter | green | + | ignition switch, 6 pin plug, pin 1 |
Second Starter | N/A | | | Ignition | orange | + | ignition switch, 6 pin plug, pin 6 | Second Ignition | N/A | | | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
| Data Bus | (only Canadian models have the immobilizer system) | | | | The data link connector is under the driver dash. |
Posted By: richl68
Date Posted: August 04, 2009 at 11:06 AM
Can Bus Sw | N/A | | | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
| | The BCM (Body Control Module) is under the driver dash, behind the fuse box. Need to use the power unlock wire and both the factory alarm disarm wire and unlock detection wire in order for the doors to unlock. |
| | The relay box is under the driver dash, above the accelerator pedal. |
| Passenger Unlock Motor | blue | 5 wire | driver kick or fuse box, gray 18 pin plug, pin 7 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
| Parking Lights (+) | green (L), yellow (R) | + | fuse box, gray 18 pin plug, pins 3 and 4 | Hazards | gray | - | BCM, 22 pin plug, pin 7 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
| Headlight | blue/black | - | headlight switch or BCM, 26 pin plug, pin 24 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. This wire only functions with the ignition on. |
Posted By: richl68
Date Posted: August 04, 2009 at 11:07 AM
AutoLights | GREEN/ black | - | headlight switch or BCM, 26 pin plug, pin 25 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
Reverse Light | blue | + | passenger kick, red 20 pin plug, pin 2 |
Left Front Door Trigger | orange | - | pass kick, yellow 22 pin plug, pin 17 or BCM, 26 pin plug, pin 15 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
| Right Front Door Trigger | same as left front door trigger | | | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
| Trunk/Hatch Pin | yellow/black | - | pass kick, yellow 22 pin plug, pin 20 or BCM, 26 pin plug, pin 17 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
| Trunk/Hatch Release | N/A | | |
Posted By: richl68
Date Posted: August 04, 2009 at 11:08 AM
Factory Alarm Arm | BROWN / orange | - | driver kick, brown 24 pin plug, pin 5 or BCM, 26 pin plug, pin 8 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. Meter this wire while turning the key in the driver door key cylinder. |
| Factory Alarm Disarm | pink and gray (double pulse) | - | driver kick, brn 24 pin plug, pins 6, 4 or BCM, 26 pin plug, pins 21, 6 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. Meter these wires while turning the key in the driver door key cylinder. Need to use the power unlock wire and both the factory alarm disarm wire and unlock detection wire in order for the doors to unlock. The gray wire is the unlock detection wire. It will meter ground when the actuator is in the unlock position. |
| Disarm No Unlock | see factory alarm disarm | | | Tachometer | blue/orange or white | ac | passenger kick, blue 24 pin plug, pin 22 | | Also found at the instrument cluster, 20 pin plug, pin 19. Can also go to any fuel injector and use the wire that is NOT pink (2.7L) or orange (3.3L). |
| Wait to Start | N/A | | | Fuel Pump | blue or yellow | + | passenger kick, red 20 pin plug, pin 17 | Rear Defroster | brown | - | rear defogger switch or BCM, 26 pin plug, pin 22 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
| | Also found in the driver kick, blue 22 pin plug, pin 19. |
Posted By: richl68
Date Posted: August 04, 2009 at 11:09 AM
Right Front Heated Seat | yellow/black | - | right seat warmer switch, black 8 pin plug, pin 5 | | Also found in the driver kick, blue 22 pin plug, pin 20. |
Speed Sense | brown | ac | data link connector, black 16 pin plug, pin 6 | | The data link connector is under the driver dash. Also found at the BCM, 16 pin plug, pin 6. The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
Brake Wire | GREEN/ black (2.7L) or gray/black (3.3L) | + | brake pedal switch | | Also found GREEN/ black (+) in the passenger kick, red 20 pin plug, pin 10. |
Parking Brake | green or gray/orange | - | parking brake switch or BCM, 26 pin plug, pin 23 | | The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
Horn Trigger | yellow/black | - | horn switch or driver kick, green 24 pin plug, pin 20 | | Also found gray/black (-) at the BCM, 22 pin plug, pin 17. The BCM (Body Control Module) is under the driver dash, behind the fuse box. |
Wipers | green (L), pink (H) | + | wiper switch, black 14 pin plug, pins 2 and 1 | | Also found in the passenger kick, green 18 pin plug, pins 8 and 7. |
Left Front Window (Up/Down) | pink - white | A | power window main switch, 14 pin plug, pins 6 and 5 | Right Front Window (Up/Down) | green - gray | A | driver kick, door harness | Left Rear Window (Up/Down) | brown - pink | A | driver kick, door harness | Right Rear Window (Up/Down) | ORANGE / black - blue | A | driver kick, door harness | Sun Roof (Open/Close) | orange - blue | - | sunroof module, gray 10 pin plug, pins 5 and 4 | | When triggering these wires, you need to supply 12V to gray at the sunroof module, gray 10 pin plug, pin 3, to turn on the sunroof module. |
Posted By: richl68
Date Posted: August 04, 2009 at 11:10 AM
Have fun
Posted By: sroake4
Date Posted: August 04, 2009 at 11:15 AM
Thank you for the very comprehensive list.
Posted By: Chris Luongo
Date Posted: August 05, 2009 at 8:39 AM
The information in that chart for the unlock wire includes unnecessary timewasters.
Use the search feature here and look for some of my older posts about this.....2007-2009 Sante Fe are all the same, so if you find a post about an '07 or '08, you can use that too.
Posted By: pettinej
Date Posted: October 08, 2009 at 5:47 PM
Anyone have problems getting the alarm to disarm on the 2009? I metered the drivers door key for wires to go to ground when you manually lock and unlock the door but these are not arming the alarm or disarming it.
I got everything working but the alarm.
