2010 toyota corolla
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117808
Printed Date: May 16, 2024 at 5:50 AM
Topic: 2010 toyota corolla
Posted By: 96hawkcnvt
Subject: 2010 toyota corolla
Date Posted: November 17, 2009 at 5:37 PM
I would appreciate it if someone could post wiring information for a 2010 Toyota Corolla. Couldn't find it in a search & my database doesn't have it listed yet. The car that I will be doing does not have push to start and I will be doing remote start only.
Also, any information from those that have done this same car would be very welcome. For example if you have run into any problems.
Thanks!
Todd
Posted By: Velocity Motors
Date Posted: November 17, 2009 at 8:01 PM
Haven't done one yet but my suggestion would be to get an iDatalink module to make the installation go easier. They have a solution for both Smart key and non-Smart key Corolla. Also, most of the connections are listed on the wire guide for the bypass module and if you use the doorlock interface and bypass module combo, you won't need to connect any door lock, trunk or trigger wires because the module will do all this for you.
------------- Jeff
