thermo fan manual switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117883
Printed Date: May 14, 2024 at 8:47 PM
Topic: thermo fan manual switch
Posted By: aussieman
Subject: thermo fan manual switch
Date Posted: November 20, 2009 at 4:02 PM
Hi all, I am hoping that someone can help me, I want to set up a switch so I can turn on the radiator fan when I want to, not when the computor wants to.
I have two speed fan, I was hoping I could tap into the low fan relay, the switch I have bought has a light in it to remind me the switch is activated, I would like to set it up so when I turn off the ignition this manual switch is deactivated as well, don't want any flat batteries, of course.
As my user name sugests , i am an aussie so I didn't include my vehilce type as you guys might not be familar with it, [1996 holden commodore] but hoping this won't be a problem with the wiring.
I would really appreciate any advise, thankyou.
Posted By: i am an idiot
Date Posted: November 20, 2009 at 5:41 PM
Does the fan relay have a constant feed to the coil and the thermostat switches the ground?
Date Posted: November 20, 2009 at 6:14 PM
I am sorry but that question is way above my knowledge, I guess this is going to be harder than I expected.
thanks for your reply though.
Date Posted: November 20, 2009 at 6:25 PM
If so and only if that is the case, the following diagram should help you.
Posted By: oldspark
Date Posted: November 20, 2009 at 7:01 PM
If the original relay is switched by grounding it, then you can simply wire a grounding switch in parallel.
(That means the relay solenoid is always hot +12V so the relay is actuated by grounding its other end. The same idea will NOT work on hot-switched system - something will blow!)
Older cars commonly used grounding for their horns - ie, a grounded horn button feeding a 3 terminal "hot" relay (or hot 4 terminal relay with +12V connected to contact & solenoid - say #30 & #86).
The core of the computer itself uses ground switching, but that will be buffered before it is presented to its output, and that buffering might change the signal to hot switching (ie, +5V or +12V output).
Ground switching is equivalent to "Open Collector" outputs as recently discussed at 12Volt's what is a 'pull up resistor'.
Date Posted: November 20, 2009 at 7:13 PM
He mentioned that the relay was controlled by the computer of the vehicle. Grounding the wire without isolating it from the computer could cause problems.
Posted By: oldspark
Date Posted: November 20, 2009 at 7:27 PM
I must stress "ONLY if the original relay is switched by grounding it".
I shall re-edit to highlight, and add ONLY.
Thanks.
PS - Dang! Wrong rules or wrong forum. I can't back edit.
I really must query management....
Please aussieman, be very aware of the implications.
At least being Aussie you'll understand my accent eh?
Date Posted: November 21, 2009 at 12:14 AM
Sorry I took so long to get back to you and thanks very much for your help guys,but I think I have bitten off more than I can chew [ so to speak ], yes I am aware of the implications that is why I didn't want to touch anything before I found out for sure if it would be ok.
I will try to explain as best I can, with an earthed testing light I can get a power out of one of the low fan relays connections, only when ignition is turn on, but nothing from the same connection when ignition is off.
So can I run a wire from that connection of the relay to a switch mounted on the dash somewere and then earth that switch to something close by ?
If it turns out to much for me, I will get a pro to do it, but I like trying to do stuff myself, if possible.
thanks again.
Posted By: oldspark
Date Posted: November 21, 2009 at 2:15 AM
Excellent info!
Alas no - yours is not earth switched.
If it was, 2 terminals would be +12V with ignition ON and fan OFF.
You may be able to parallel a second relay - ie, from +12V to the fan (and turned on buy a dash switch) - but that depends on the wiring - it could be damaging.
So it looks like you need to get a pro. (Rats!)
Date Posted: November 27, 2009 at 1:51 PM
Solved, second relay was earth.
thanks for your help and a special thank you to oldspark.
