2009 Nissan Sentra Remote Start/Keyless Entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119142
Printed Date: May 05, 2024 at 2:03 AM
Topic: 2009 Nissan Sentra Remote Start/Keyless Entry
Posted By: isreal
Subject: 2009 Nissan Sentra Remote Start/Keyless Entry
Date Posted: January 06, 2010 at 10:41 AM
Hey guy's new to the forum but love the site. Anyway, I am in need of a Vehicle wiring guide for a 2009 nissan sentra for remote start/keyless entry. I have looked everywhere online and cannot find one for the life of me. If it is the same as 2008 than I'm all set but I'm not sure if it is. Also I don't know what interface module i should use. Supposed to do this Monday so I hope someone out there can help me! Thanks in advance!
Posted By: reyhb
Date Posted: January 07, 2010 at 7:14 PM
Battery BROWN AND ORANGE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PINS 12/33 OF 40 PIN PLUG
PSC/ECU TO THE FAR RIGHT BEHIND GLOVE BOX
Ignition 1 YELLOW (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 35 OF 40 PIN PLUG
Ignition 2 LIGHT BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN34 OF 40 PIN PLUG
Accessory 1 GREEN (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 11 OF 40PIN PLUG
Starter 1 BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 15 OF 40 PIN PLUG
Starter 2 LIGHT BLUE (+) PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 17 OF 40 PIN PLUG
Anti-Theft Type UNIVERSAL TRANSPONDER
Anti-Theft Descript THE KEY SENDS A RF SIGNAL TO THE BCM THROUGH A ANTENNA AROUND THE KEY CYLINDER
Key Sense BLUE/WHITE (-) IGNITION SWITCH HARNESS
Neutral Safety GREEN / WHITE (-) AT GEAR SELECTOR SWITCH
Tachometer WHITE (AC) PIN 9 AT THE DATA CONNECTOR
Speed Sense PURPLE (AC) ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
Parking Lights GREEN (+) AT THE BACK OF PARKING LIGHT UNDER HOOD
Low Crr. Pk Lights RED / YELLOW (-) LIGHT SWITCH HARNESS
Brake Lights RED / BLACK (+) BRAKE PEDAL
Reverse Lights RED (+) ECU PIN13
Horn YELLOW (-) STEERING COLUMN HARNESS
Rear Defrost BROWN / YELLOW
MAY BE BROWN ON SOME MODELS
Posted By: reyhb
Date Posted: January 07, 2010 at 7:16 PM
WIRE COLOR posted_image POLARITY LOCATION
Power Unlock LIGHT GREEN (-) POWER MASTER SWITCH IN DRIVERS DOOR
PowerLock PINK (-) POWER MASTER SWITCH IN DRIVERS DOOR
REQUIRES DOUBLE PUSLE
Driver Mtr Unlock RED (REV) ECU IN DRIVERS DOOR
Driver Mtr Lock GREEN (REV) ECU IN DRIVERS DOOR
Pas Mtr Unlock RED (REV) ECU IN PASSENGER DOOR
LF Window Up RED / YELLOW (REV) DRIVERS DOOR SWITCH
LF Window Dn RED / BLUE (REV) DRIVERS DOOR SWITCH
RF Window Up BLUE / YELLOW (REV) DRIVER KICK PANEL
RF Window Dn BLUE (REV) DRIVER KICK PANEL
