2010 nissan pathifnder
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121360
Printed Date: June 08, 2024 at 5:52 AM
Topic: 2010 nissan pathifnder
Posted By: slammedniss
Subject: 2010 nissan pathifnder
Date Posted: April 15, 2010 at 2:48 PM
Wiring diagram request
Posted By: mpe235
Date Posted: November 08, 2010 at 8:26 PM
MODEL |
YEAR(S) |
PATHFINDER |
2007 -2010 |
KEY |
T-HARNESS |
IMMOBILIZER |
N/A |
N/A |
NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 |
PART |
COLOR |
LOCATION |
12 VOLT CONSTANT |
GREEN (+) 40 AMP |
@ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 3 |
STARTER |
GRAY (+) |
@ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 2 |
STARTER 2 |
LT. GREEN (+) |
@ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 6 |
IGNITION 1 |
WHITE/ GREEN (+) |
@ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 1 |
IGNITION 2 |
N/A |
IGNITION 3 |
N/A |
ACCESSORY /HEATER BLOWER 1 |
RED (+) |
@ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 4 |
ACCESSORY /HEATER BLOWER 2 |
GREEN/ YELLOW (+) |
@ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 5 |
KEYSENSE |
N/A |
PARKING LIGHTS ( - ) |
N/A |
PARKING LIGHTS ( + ) |
GRAY (+) |
POWER LOCK |
LT. BLUE (-), TYPE B, NOTE #3 |
@ POWER WINDOW Main Switch, ( WHITE, 16-PIN PLUG), PIN 4 |
POWER UNLOCK |
RED / WHITE (-), TYPE B, Requires Double Pulse, NOTE #4 |
@ POWER WINDOW Main Switch, ( WHITE, 16-PIN PLUG), PIN 6 |
DOOR TRIGGER |
GRAY (-) |
in DRIVERS KICK PANEL or BCM, (WHITE, 15-PIN PLUG), PIN 7, NOTE #2 |
DOMELIGHT SUPERVISION |
BROWN (-) |
in DRIVERS A Pillar or BCM, (BLACK, 15-PIN PLUG), PIN 8, NOTE #2 |
TRUNK RELEASE |
GREEN or LT. BLUE (-) NOTE #5 |
in DRIVERS KICK PANEL or BCM, (WHITE, 40-PIN PLUG), PIN 30, NOTE #2 |
SLIDING POWER DOOR |
N/A |
HORN |
BROWN (-) |
@ HORN Switch, (GRAY-8-PIN PLUG), PIN 2 or in DRIVERS KICK PANEL |
TACH |
Any wire NOT WHITE/ GREEN (AC) |
@ Any FUEL-INJECTOR |
WAIT TO START LIGHT |
N/A |
BRAKE |
YELLOW (+) |
@ BRAKE SWITCH or in DRIVERS KICK PANEL, Harness to REAR of Vehicle |
FACTORY ALARM DISARM |
Use UNLOCK wire |
ANTI-THEFT |
EXTRA INFORMATION |
NOTE #1: NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 (For REMOTE START ONLY) Part # DLPK-CANBUS MULTI (for REMOTE START and DOOR LOCKS) NOTE #2: the BCM (Body Control Module) is located under the Drivers Dash and to the RIGHT of the Steering Column. NOTE #3: TEST this wire while Turning the KEY in the Drivers Door. This wire will also ARM the FACTORY ALARM. NOTE #4: TEST this wire while Turning the KEY in the Drivers Door. This wire will also DISARM the FACTORY ALARM. NOTE #5: TEST this wire while opening the LIFTGATE with the Handle on the REAR of the Vehicle. |
;> ------------- Nissan Master Tech.
