Is anyone has 2009 Acura TSX wiring color.
This info from Bulldog Security
TSX 2009 -2010
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) 50 AMP @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 2
STARTER YELLOW (+) @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 1
STARTER 2 N/A
IGNITION 1 BLUE (+) @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 5
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 3
ACCESSORY /HEATER BLOWER 2 RED (+) @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 4
KEYSENSE N/A
PARKING LIGHTS ( - ) GRAY (-) @ HEADLIGHT SWITCH, (BLACK/ WHITE, 12-Pin Plug) Pin 11
PARKING LIGHTS ( + ) RED (+) Left Front and Rear) @ DRIVERS FUSE BOX, (LT. GREEN, 16-Pin Plug) Pin 11
POWER LOCK ORANGE (-) TYPE B, @ POWER WINDOW MASTER SWITCH, ( GRAY, 37-Pin Plug) Pin 28
POWER UNLOCK BROWN (-) & WHITE (-) TYPE B, Requires Double Pulse @ POWER WINDOW MASTER SWITCH, ( GRAY, 37-Pin Plug) Pins 29 and 31
DOOR TRIGGER BROWN (-) @ DRIVERS FUSE BOX, (LT. GREEN, 16-Pin Plug) Pin 12
DOMELIGHT SUPERVISION PINK (-) below DRIVERS FUSE BOX, (WHITE, 20-Pin Plug) Pin 1
TRUNK RELEASE PINK (-) @ DRIVERS FUSE BOX, (LT. GREEN, 20-Pin Plug) Pin 3
SLIDING POWER DOOR N/A
HORN ORANGE or GRAY (-) @ HORN SWITCH or DRIVERS DASH FUSE BOX, (LT. GREEN, 33-Pin Plug) Pin 23
TACH Any wire NOT YELLOW/BLACK @ Any FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE LT.GREEN (+) @ BRAKE SWITCH or DRIVERS FUSE BOX (LT. GREEN, 33-Pin Plug) Pin 20
FACTORY ALARM DISARM See UNLOCK
ANTI-THEFT HONDA'S TRANSPONDER SYSTEM, Requires Bypass Module,
thanks alots for the information i also has a question,how do you hook up to trunk release.
