2011 Hyundai Sonata Remote Start Wire Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123005
Printed Date: April 27, 2024 at 5:41 PM
Topic: 2011 Hyundai Sonata Remote Start Wire Diagram
Posted By: claymansrt
Subject: 2011 Hyundai Sonata Remote Start Wire Diagram
Date Posted: August 06, 2010 at 11:06 PM
Hello, does anybody have a wire diagram for a 2011 Hyundai Sonata, I'm trying to install a remote starter but do not know which wires to tap in the ignition harness. Thank you, i know its pretty new but i'm taking a shot in the dark here.
Posted By: icearrow6
Date Posted: August 08, 2010 at 5:30 PM
2011 Hyundai Sonata
HYUNDAI
MODEL YEAR(S)
SONATA 2011 -
KEY T-HARNESS IMMOBILIZER
N/A N/A HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
PART COLOR LOCATION
12 VOLT CONSTANT GREEN (+) 30 AMP, NOTE #2 @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 1
STARTER YELLOW (+), NOTE #3 @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 3
STARTER 2 YELLOW/BLACK and YELLOW/ORANGE (+) (PUSH-BUTTON START) @ START/STOP BUTTON SWITCH, (BLACK, 10-PIN PLUG), PINS 1 and 7
IGNITION 1 PINK (+), NOTE #4 @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 4
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 ORANGE (+), NOTE #5 @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 2
ACCESSORY /HEATER BLOWER 2 BLUE (+), NOTE #6 @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 6
KEYSENSE N/A
PARKING LIGHTS ( - ) PINK (-) @ HEADLIGHT SWITCH or BCM, (GRAY, 24-PIN PLUG), PIN 22, NOTE #9
PARKING LIGHTS ( + ) GREEN/ BLACK(+)(Left) and BROWN / BLACK(+)(Right) use both @ DASH FUSE BOX, (BLACK, 39-PIN PLUG(A), PINS 25 and 7
POWER LOCK WHITE (-), TYPE B @ DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PIN 13
POWER UNLOCK YELLOW (-), TYPE B, NOTE #7 @ DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PIN 1
DOOR TRIGGER BROWN (-) @ DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PIN 7
DOMELIGHT SUPERVISION YELLOW/BLACK (-) @ BCM, (WHITE, 24-PIN PLUG), PIN 4, NOTE #9
TRUNK RELEASE WHITE (-) @ TRUNK RELEASE SWITCH or DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PIN 2
SLIDING POWER DOOR N/A
HORN WHITE (-) @ HORN SWITCH or in DRIVERS KICK PANEL, (WHITE, 43-PIN PLUG), PIN 42
TACH WHITE, BLUE, YELLOW or ORANGE, (AC) @ Any FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE GREEN (+) @ BRAKE PEDAL SWITCH or in DRIVERS KICK PANEL, ( WHITE, 43-PIN PLUG), PIN 34
FACTORY ALARM DISARM ORANGE and BROWN (-), Requires Double Pulse, NOTE #8 @ DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PINS 16 and 22
ANTI-THEFT HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE #1: HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 Bypass Module for REMOTE START NOTE #2: on Vehicles with SMART KEY, use GREEN, RED and PINK (+) 60 AMP, at the DASH FUSE BOX, (BLACK, 3-PIN PLUG(C), PINS 1, 2 and 3. NOTE #3: on Vehicles with SMART KEY, use YELLOW (+), at the DASH FUSE BOX, (REAR BLACK, 39-PIN PLUG(E), PIN 39 NOTE #4: on Vehicles with SMART KEY, use PINK (+), at the DASH FUSE BOX, (REAR BLACK, 39-PIN PLUG(E), PIN 14 NOTE #5: on Vehicles with SMART KEY, use ORANGE(+), at the DASH FUSE BOX, (REAR BLACK, 39-PIN PLUG(E), PIN 1 NOTE #6: on Vehicles with SMART KEY, use BLUE(+), at the DASH FUSE BOX, (REAR BLACK, 39-PIN PLUG(E), PIN 27 NOTE #7: to UNLOCK just the DRIVERS DOOR use the YELLOW/ORANGE(-) at the DASH FUSE BOX, (REAR WHITE, 24-PIN PLUG(F), PIN 10 NOTE #8: TEST these wires while Turning the KEY in the DRIVERS DOOR NOTE #9: the BCM, (Body Control Module) is located under the DRIVERS DASH, above the GAS PEDAL.
Posted By: kreg357
Date Posted: August 09, 2010 at 9:53 PM
The Bulldog info posted above was very accurate for a GLS non push to start.
Here is a link to some more info... https://www.the12volt.com/installbay/forum_posts.asp~TID~121381~PN~1 As noted, be very gentle with the ignition wires, the switch comes apart easily.
Here is a picture of the BCM with the Defrost, Auto Headlights and Parking lights marked.
Enjoy! ------------- Soldering is fun!
Posted By: city74
Date Posted: October 13, 2010 at 6:23 AM
Hello, I'm trying to install a remote starter on 2011 Hyundai Sonata with smart key. Can i use XK09 DLPKHY W2W for realise remote starter? Thanks.
------------- city74
Posted By: racerjames76
Date Posted: February 16, 2011 at 11:50 AM
Anyone have any info on VSS for the 2011 sonata?
------------- To master and control electricity is perfection. *evil laugh*
Posted By: frizzo
Date Posted: March 03, 2011 at 12:52 PM
