2007 buick lucerne
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123526
Printed Date: June 09, 2024 at 4:52 AM
Topic: 2007 buick lucerne
Posted By: heinstal
Subject: 2007 buick lucerne
Date Posted: September 15, 2010 at 8:30 AM
anyone got the wiring info for this car including vss wire? please and thank you :D
~~~WAEL~~~
Posted By: ipv_zach
Date Posted: September 15, 2010 at 10:00 PM
12 V - 14 ga. RED / White at BCM above Passengers kick pannel in Black connector.
Ignition - 18 ga. Pink at same in green connector
ACC - 18 ga. brown at same in green connector
Starter - Connect accessory to ignition through relay to prevent vehicle from starting. Connect ignition PINK to terminals 87 and 86. Connect accsesory BROWN to terminal 30. Connect armed (-) out of alarm to 85.
Horn - 18 ga. Tan at same in brown connector.
Lights (-) 18 ga. Gray/Blue at interior light switch assembly on left side of dash.
Door 1 - 18 ga. Gray/Black(-) in drivers door.
Door 2 - 18 ga. Tan/White(-) in pass door.
Door 3 - 18 ga. Lt. Blue/Black(-) at B.C.M. in Pink connector.
Door 4 - 18 ga. Pink/Black(-) at same.
Trunk Trigger - 18 ga. ORANGE / Gray(-) at same
Hood Pin - 18 ga. Pink/Black in Black connector.
Interior Lights - 18 ga. Pink/Black(-) at same in white connector, or 16 ga. Gray/Black(+) in Pink connector.
Trunk Release - 18 ga. Lt. Blue(-) at same in White connector, motor wire is Tan/White(+) in Gray connector.
Lock (switch) - MPX from door switches
Unlock (switch) same
Disarm (key) - In drivers door, also unlocks doors on second pulse.
Arm Input - 14 ga. Gray (M) at either side rear running board, wire is for rear doors only.
Disarm Input 1 - 14 ga. Tan (M) in drivers door only.
Disarm Input 2 - 14 ga. Tan (M) at same as arm input
alarmwizard
Posted By: heinstal
Date Posted: September 17, 2010 at 7:35 AM
perfect! thanks! anything on the speed signal wire for this car???
~~~WAEL~~~
Posted By: 91stt
Date Posted: September 17, 2010 at 12:55 PM
VSS: Violet / Black @ PCM inside air cleaner plug C1 pin #22 or Throttle actuator control module on throttle boby assembly pin #4
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Posted By: heinstal
Date Posted: September 18, 2010 at 12:00 PM
perfect! thanks guys
~~~WAEL~~~
