2003 audi a4 wiring for ccm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125779
Printed Date: May 11, 2024 at 10:55 AM
Topic: 2003 audi a4 wiring for ccm
Posted By: angelsounds
Subject: 2003 audi a4 wiring for ccm
Date Posted: January 21, 2011 at 1:57 PM
Anyone have a wiring schematic for an 03 Audi A4, either the ccm module or the factory keyless?
I already tried directwire.
Im trying to add a remote start to my factory remotes, but i need to figure out what wire
to interupt so my factory keyless will still operate while the the car is remote started.
The factory remote doesnt work once the ignition is on.
Any help would be great!
Posted By: howie ll
Date Posted: January 21, 2011 at 6:04 PM
Don't even try this one, it's all done by CAN, you'd need an Audi specific by-pass.
Posted By: howie ll
Date Posted: January 21, 2011 at 6:36 PM
Actually I had a thought, the factory lock/alarm module should be in the left hand rear wedged in just in front of the rear lights.
find the lead probably BLACK/ blue that goes to 12volts+ when the ignition is turned on.
Use the GWR or status output from your R/S to a relay to open circuit this wire. It might work.
Posted By: 91stt
Date Posted: January 21, 2011 at 9:45 PM
Howie, that's not going to work. The comfort system control module does not have a switched 12V connection. Seems that it is a data signal that controls that function. ------------- This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Posted By: howie ll
Date Posted: January 22, 2011 at 1:40 AM
As per my first post, maybe the second one was wishful thinking!
In truth I try to run away from any Audi after 2002.
Date Posted: January 28, 2011 at 8:41 AM
I guess im gonna have to put in a whole unit. Was kinda wanting just to carry around just the factory remote only, but i guess not.
