2011 bmw 740li
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131036
Printed Date: April 08, 2026 at 5:49 PM
Topic: 2011 bmw 740li
Posted By: asetliff
Subject: 2011 bmw 740li
Date Posted: March 26, 2012 at 12:00 PM
Need the basic remote start stuff for 2011 BMW 740LI.
Thanks in advance.
Posted By: howie ll
Date Posted: March 28, 2012 at 11:51 AM
First, go to Fortin or Xpresskit, it isn't just a remote start.
Posted By: asetliff
Date Posted: March 29, 2012 at 9:48 PM
I'm just trying to keep it simple. I'm not trying to crank it but rather disable the starter. To be more specific I need:
12+
Ignition
Starter
Horn
Lights
Horn and lights is needed by not necessary.
I've used fortin before as a reference and have not had much luck lately as everything is member stuff. It used to be my ace in the hole and everyone with my company thought I was the wiring genius. Will check out your other site.
Thanks and I still need the info above if anyone has it. I'm not trying to start it but rather keep it from starting.
Posted By: howie ll
Date Posted: March 30, 2012 at 3:27 AM
12V+ Red 41 pin plug at Car Access System, right of steering column 21.
Ignition, green + at same point and plug, pin 1.
Starter, black + at same, pin 22.
Hazards will be easier than lights, BROWN / blue -, driver's kick well module, 26 pin plug, pin 6.
Horn, RED / brown +, at dash fuse box, plug 8B pin 6....steering column? Or is that DATA.
Above info is for a 2009, but if the body shell and interior are the same?
Posted By: asetliff
Date Posted: April 01, 2012 at 8:46 PM
Thank you sir!
