2012 yaris vss wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131135
Printed Date: April 07, 2026 at 11:32 PM
Topic: 2012 yaris vss wire?
Posted By: audio2go
Subject: 2012 yaris vss wire?
Date Posted: April 06, 2012 at 9:31 PM
I have exhausted all of my wiring sources, and none of them seem to have definitive information on where to locate a VSS wire and what color it might be. Any info would be greatly appreciated.
------------- "They dont work once you let the smoke out"
Posted By: kreg357
Date Posted: April 06, 2012 at 10:04 PM
Here is info for a 2010 Yaris : Vehicle Speed Sense VIOLET (AC) DASH FUSE BOX WHITE 36 PIN CONN, PIN 26 Some of the other wires for a R/S look the same so hopefully this one hasn't changed.
------------- Soldering is fun!
Posted By: howie ll
Date Posted: April 07, 2012 at 11:12 AM
Shouldn't that also be on the radio loom, prepared for when there's a factory Sat Nav?
Posted By: howie ll
Date Posted: April 07, 2012 at 11:13 AM
Stop press, left hand side of instrument panel. Same colour.
Posted By: audio2go
Date Posted: April 07, 2012 at 11:35 PM
I would normally assume the same, except I now also have a 2011 Yaris here, and the junction block under the dash is completely different. Then I had a brainfart. The radio has auto level control, so the wire is probably at the back of the radio too. Will need to test....
Posted By: audio2go
Date Posted: April 07, 2012 at 11:45 PM
Sorry Howie, I didnt read you post before my reply. By same color, you mean Violet, like in the 2010? What do you mean by "stop press"? There is a violet at the back of the radio too. Thanks for the info and your signature is dead on.
Posted By: howie ll
Date Posted: April 08, 2012 at 2:48 AM
The stop press was because I had the brain fart immediately after the first post!
I was alarming one, had the centre section out around the radio and saw it up to the left but be careful, I'm talking about local (UK) build right hand drive, but radios are always set up the same physically so it should be there.
Same colour, alternate was violet/white.
Posted By: howie ll
Date Posted: April 08, 2012 at 2:54 AM
Sorry, boring I know but I actually did a Kregg!
2012 according to Directechs:-
Dash fusebox, white 40 pin plug marked 3C pin 39 violet (purple). ------------- Amateurs assume, don't test and have problems; pros test first. I am not a free install service.
Posted By: kreg357
Date Posted: April 08, 2012 at 5:31 AM
When in doubt, go to the reference manuals, and then test...  ------------- Soldering is fun!
Posted By: audio2go
Date Posted: April 08, 2012 at 3:58 PM
Ok, here it is: The VSS wire is Violet, pin number 17 on the 28 pin connector at the back of the radio. Tested and confirmed. Thanks to all.
