Print Page | Close Window |
2013 Ford Taurus Alarm/Remote Start/Stereo WiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131604 Printed Date: May 01, 2024 at 6:50 PM Topic: 2013 Ford Taurus Alarm/Remote Start/Stereo Wiring Posted By: isa-kuruption Subject: 2013 Ford Taurus Alarm/Remote Start/Stereo Wiring Date Posted: June 13, 2012 at 8:46 AM Looking for any and all wiring information (audio and security) for a 2013 Ford Taurus (SHO model / Sony radio / Navigation). I believe it may be the same as the 2012 model year, but not sure. Thanks.
Replies: Posted By: lurch228 Date Posted: November 02, 2012 at 10:12 PM DIRECTWIRE™ WIRING INFORMATION - FORD / TAURUS / 2013 / Security [PRINT THIS PAGE] 12volts yellow/red (5A) + ignition switch, black 7 pin plug, pin 4 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Starter blue/white + ignition switch, black 7 pin plug, pin 7 Ignition WHITE/ orange + ignition switch, black 7 pin plug, pin 1 Power Lock blue/green (test with pass sw on models w/memory) - BCM, black 26 pin plug (C), pin 6 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Power Unlock yellow/purple (test with pass sw on models w/mem) - BCM, black 26 pin plug (C), pin 8 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Lock Motor gray/brown 5 wire driver kick, harness to rear Unlock Motor blue/green (models without memory) 5 wire driver kick, door harness Notes: On models with memory, it is blue/green (5 wire) at the Driver Door Module, black 24 pin plug, pin 10. Disarm Defeat PURPLE / gray 5 wire driver kick, harness to rear Parking Lights+ yellow/blue + BCM, gray 10 pin plug (E), pin 6 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Parking Lights- gray - headlight switch, gray 10 pin plug, pin 2 Notes: May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ white at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information. Hazards BROWN / yellow - BCM, black 52 pin plug (B), pin 32 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Turn Signal(L) blue/green (F); gray/orange (R) + BCM, brown 26 pin plug (F), pin 8; black 26 pin plug (C), pin 14 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Turn Signal(R) yellow/purple (F); GREEN/ orange (R) + BCM, brown 26 pin plug (F), pin 7; black 26 pin plug (C), pin 15 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Door Trigger GREEN/ purple - N.C. BCM, black 26 pin plug (C), pin 9 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Dome Supervision gray/purple (dome lamp); purple (puddle lamp) + BCM, gray 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Trunk/Hatch Pin gray/orange - N.C. BCM, black 26 pin plug (C), pin 19 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Hood Pin blue/orange - N.C. BCM, brown 26 pin plug (F), pin 2 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Trunk/Hatch Release BROWN / yellow - release switch, blk 6 pin plg, pin 6 or BCM, blk 26 pin plg (C), pin 23 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Power Sliding Door N/A Factory Alarm Arm arms on lock with door open Factory Alarm Disarm see disarm no unlock Disarm No Unlock Transponder and ignition Tachometer grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh ac any fuel injector, white 2 pin plug, pin 1 (3.5L/3.7L TIVCT) Notes: On 2.0L GTDI models, the fuel injector wires are GREEN/ blue, gray / YELLOW, PURPLE / gray, or yellow/orange at the lower front of the engine, black 16 pin plug, pin 1, 4, 5, or 6. On 3.5L GTDI models, the fuel injector 4-6 wires are yellow/orange, brown, or GREEN / WHITE at the top center of the engine, black 12 pin plug, pin 2, 3, or 4. Horn Trigger PURPLE / green - horn switch or BCM, black 52 pin plug (B), pin 33 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Memory Seat 1 PURPLE / white - driver kick, harness to rear Memory Seat 2 yellow - driver kick, harness to rear Memory Seat 3 N/A - Interface Modules: Not Available This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. DIRECTWIRE™ WIRING INFORMATION - FORD / TAURUS / 2013 / Remote Start [PRINT THIS PAGE] 12volts yellow/red (5A) + ignition switch, black 7 pin plug, pin 4 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Starter blue/white + ignition switch, black 7 pin plug, pin 7 Second Starter N/A Ignition WHITE/ orange + ignition switch, black 7 pin plug, pin 1 Second Ignition N/A Third Ignition N/A Accessory PURPLE / green + ignition switch, black 7 pin plug, pin 6 Second Accessory N/A Keysense blue/gray + ignition switch, black 7 pin plug, pin 5 Power Lock blue/green (test with pass sw on models w/memory) - BCM, black 26 pin plug (C), pin 6 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Power Unlock yellow/purple (test with pass sw on models w/mem) - BCM, black 26 pin plug (C), pin 8 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Lock Motor gray/brown 5 wire driver kick, harness to rear Unlock Motor blue/green (models without memory) 5 wire driver kick, door harness Notes: On models with memory, it is blue/green (5 wire) at the Driver Door Module, black 24 pin plug, pin 10. Parking Lights+ yellow/blue + BCM, gray 10 pin plug (E), pin 6 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Parking Lights- gray - headlight switch, gray 10 pin plug, pin 2 Notes: May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ white at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information. Hazards BROWN / yellow - BCM, black 52 pin plug (B), pin 32 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Turn Signal(L) blue/green (F); gray/orange (R) + BCM, brown 26 pin plug (F), pin 8; black 26 pin plug (C), pin 14 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Turn Signal(R) yellow/purple (F); GREEN/ orange (R) + BCM, brown 26 pin plug (F), pin 7; black 26 pin plug (C), pin 15 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Reverse Light blue/white + BCM, white 32 pin plug (D), pin 13 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Door Trigger GREEN/ purple - N.C. BCM, black 26 pin plug (C), pin 9 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Dome Supervision gray/purple (dome lamp); purple (puddle lamp) + BCM, gray 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Trunk/Hatch Pin gray/orange - N.C. BCM, black 26 pin plug (C), pin 19 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Hood Pin blue/orange - N.C. BCM, brown 26 pin plug (F), pin 2 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Trunk/Hatch Release BROWN / yellow - release switch, blk 6 pin plg, pin 6 or BCM, blk 26 pin plg (C), pin 23 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Power Sliding Door N/A Factory Alarm Arm arms on lock with door open Factory Alarm Disarm see disarm no unlock Disarm No Unlock Transponder and ignition Tachometer grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh ac any fuel injector, white 2 pin plug, pin 1 (3.5L/3.7L TIVCT) Notes: On 2.0L GTDI models, the fuel injector wires are GREEN/ blue, gray / YELLOW, PURPLE / gray, or yellow/orange at the lower front of the engine, black 16 pin plug, pin 1, 4, 5, or 6. On 3.5L GTDI models, the fuel injector 4-6 wires are yellow/orange, brown, or GREEN / WHITE at the top center of the engine, black 12 pin plug, pin 2, 3, or 4. Wait to start N/A Brake Wire PURPLE / white + brake switch or BCM, black 52 pin plug (B), pin 28 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Parking Brake WHITE/ purple - parking brake switch or BCM, black 26 pin plug (C), pin 7 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Horn Trigger PURPLE / green - horn switch or BCM, black 52 pin plug (B), pin 33 Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash. Memory Seat 1 PURPLE / white - driver kick, harness to rear Memory Seat 2 yellow - driver kick, harness to rear Memory Seat 3 N/A - Interface Modules: Not Available This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery WHITE/ RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Power Antenna WHITE (+) RADIO HARNESS Amp Turn On VIOLET/RED (+) RADIO HARNESS Amp Location LOCATED BEHIND TRIM ON LEFT SIDE OF TRUNK THERE IS A SONY DSP MODULE AND A SEPERATE AUDIO AMPLFIER NEXT TO IT - BOTH PROVIDE AUDIO SIGNAL TO THE SPEAKERS. Steering Cntrls OPTIONAL Speed Cntrl YES Radio Security YES - VIN CODED Security WIRE COLOR POLARITY LOCATION Battery BLUE/RED (+) IGNITION SWITCH HARNESS Ignition 1 GREEN/ VIOLET (+) IGNITION SWITCH HARNESS Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS All Door Trigger GRAY/VIOLET (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Domelight Super GRAY/VIOLET (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH LF Latch GREEN/ VIOLET (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH RF Latch WHITE (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH LR Latch GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH RR Latch YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Trunk Trigger YELLOW /GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Hood Trigger BLUE/ORANGE (OPEN) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH THIS SWITCH RESTS AT (-) AND IS OPEN WHEN THE HOOD IS OPENED. Parking Lights GRAY (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo BROWN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Headlights-Hi WHITE/ ORANGE (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH LF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT LEFT PARKING LIGHT RF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT RIGHT PARKING LIGHT LR Pk Lt Bulb VIOLET/WHITE (+) AT REAR LEFT PARKING LIGHT RR Pk Lt Bulb VIOLET/WHITE (+) AT REAR RIGHT PARKING LIGHT All Hazrd Lights BROWN / YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH LF Hazrd Bulb BLUE/GREEN (+) AT FRONT LEFT DIRECTIONAL LIGHT RF Hazrd Bulb YELLOW/VIOLET (+) AT FRONT RIGHT DIRECTIONAL LIGHT LR Hazrd Bulb GRAY/ORANGE (+) AT REAR LEFT DIRECTIONAL LIGHT RR Hazrd Bulb GREEN/ ORANGE (+) AT REAR RIGHT DIRECTIONAL LIGHT Wipers-Lo GREEN/ VIOLET (-) IN HARNESS AT VEHICLE WIPER SWITCH Wipers-Hi VIOLET/ORANGE (-) IN HARNESS AT VEHICLE WIPER SWITCH Parking Brake WHITE/ VIOLET (-) AT SWITCH ABOVE PEDAL Trnk Release BROWN / YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Seat Mem 1 VIOLET/WHITE (-) AT SEAT MODULE UNDER DRIVERS SEAT Seat Mem 2 YELLOW (-) AT SEAT MODULE UNDER DRIVERS SEAT Remote Start WIRE COLOR POLARITY LOCATION Battery BLUE/RED (+) IGNITION SWITCH HARNESS Ignition 1 GREEN/ VIOLET (+) IGNITION SWITCH HARNESS Accessory 1 VIOLET/GREEN (+) IGNITION SWITCH HARNESS Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS Anti-Theft Type FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER Key Sense BLUE/GRAY (+) IGNITION SWITCH HARNESS Neutral Safety GREEN (-) IN HARNESS AT REAR OF GAUGES SHOWS (-) IN PARK OR NEUTRAL. Crankshaft Sensor GREEN/ BROWN (AC) AT PCM MODULE AT CENTER OF FIREWALL UNDER HOOD Camshaft Sensor BROWN / BLUE (-) AT PCM MODULE AT CENTER OF FIREWALL UNDER HOOD Parking Lights GRAY (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Brake Lights VIOLET/WHITE (+) AT SWITCH ABOVE PEDAL Reverse Lights GREEN/ BROWN (+) IN HARNESS AT REARVIEW MIRROR OR IN DRIVERS SIDE A-PILLAR Horn YELLOW/RED (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Anti Theft RX VIOLET/GRAY (DATA) AT PATS RECEIVER NEAR IGNITION SWITCH Anti Theft TX YELLOW/ORANGE (DATA) AT PATS RECEIVER NEAR IGNITION SWITCH Rear Defrost WHITE/ ORANGE (-) IN HARNESS AT REAR OF HVAC CONTROL PANEL Heated Driver Seat WHITE/ BLUE (-) AT HVAC MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH Heated Passngr Seat GRAY / YELLOW (-) AT HVAC MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH Modules WIRE LOCATION Please select another category Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock YELLOW/VIOLET (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH PowerLock BLUE/GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH Driver Mtr Unlock BLUE/GREEN (REV) AT MOTOR IN DOOR Driver Mtr Lock VIOLET/GREEN (REV) AT MOTOR IN DOOR Pas Mtr Unlock VIOLET/GRAY (REV) AT MOTOR IN DOOR Pas Mtr Lock VIOLET/GREEN (REV) AT MOTOR IN DOOR LF Window Up BLUE/GRAY (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR LF Window Dn YELLOW/VIOLET (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR RF Window Up BROWN / YELLOW (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR RF Window Dn GREEN/ ORANGE (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR LR Window Up BLUE/ORANGE (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR LR Window Dn YELLOW (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR RR Window Up GRAY/VIOLET (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR RR Window Dn BROWN / GREEN (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR Sunroof Open VIOLET/WHITE (-) AT SUNROOF MODULE IN ROOF Sunroof Close VIOLET/BROWN (-) AT SUNROOF MODULE IN ROOF |
