body control and comfort closure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132104
Printed Date: May 15, 2024 at 5:40 PM
Topic: body control and comfort closure
Posted By: jin01
Subject: body control and comfort closure
Date Posted: August 30, 2012 at 12:06 PM
installed a 2.2x matrix on a Mitsubishi colt everything works so far but there is no way to hook up the comfort closure` as my auto electrician says he have no idea how to run it with the body control module
Posted By: awdeclipse
Date Posted: August 30, 2012 at 12:19 PM
I was under the impression this is only an option on certain vehicles. Most posts I have read in the past accomplish this, on eligible vehicles, by extending the lock pulse. This can be tested by rolling the windows down and using the key in the door and holding lock to see if the windows roll up.
Posted By: howie ll
Date Posted: August 31, 2012 at 2:29 AM
Not to be confused with one-touch up and down.
This only works when the vehicle has it ex factory, e.g. BMW, Audi, Mercedes, VW some Accords, Euro Fords and GM.
Never seen it on a Mits.
If your driver door switches work for up to a minute after turning off the ignition don't even bother.
On these (some models) the door control unit is mounted directly to the motor, on some models (Pajero/Montero/Shogun 2000 on), the motor wires are internal, don't even attempt.
I once had a 2000 Gallant and even with external wiring I STILL had to drop the rear door motors for access.
Most installers won't touch this job for all the money in the world.
Basically your installer is correct but if I were he I would charge you to take the door panel off and look at the motor wiring before proceeding.
Posted By: jin01
Date Posted: August 31, 2012 at 10:27 PM
well it does. he wouldn't charge me tho, but if it cant be done or its a waste of time to attempt ill tell him to call it quits cause he sent me to find out some info
Posted By: howie ll
Date Posted: September 01, 2012 at 12:48 AM
The next stage is up to an hour fiddling around inside a door panel, except for the two seconds it takes to pop the windows between turning off the key and exiting the vehicle it just isn't worth it, believe me I've been there.
Drop the motor and there's a good chance it has to go back to the dealer to re-initialise it before it works properly again.
