2010 Ford Mustang Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132926
Printed Date: May 02, 2024 at 6:29 AM
Topic: 2010 Ford Mustang Alarm/Remote Start Wiring
Posted By: koncept21
Subject: 2010 Ford Mustang Alarm/Remote Start Wiring
Date Posted: December 09, 2012 at 2:02 PM
Hello i recently purchased a Viper 5904 alarm and need a wiring diagram for my 2010 ford mustang. I was using the same one for the 2012 but i believe its not the same one. I need to also find out the location of the 52 pin plug. Thanks for the help
Posted By: shortcircuit161
Date Posted: December 09, 2012 at 11:57 PM
2010 and up should be the same wiring.
DIRECTWIRE™ WIRING INFORMATION - FORD / MUSTANG / 2010 / Remote Start
[PRINT THIS PAGE]
12volts red (80A) + SJB, black 1 pin plug (G), pin 1
Notes: The SJB (Smart Junction Box) is in the passenger kick.
Starter blue/white + ignition switch, black 7 pin plug, pin 7
Second Starter N/A
Ignition gray/purple + ignition switch, black 7 pin plug, pin 1
Second Ignition N/A
Third Ignition N/A
Accessory PURPLE / green + ignition switch, black 7 pin plug, pin 6
Second Accessory N/A
Keysense blue/gray + ignition switch, black 7 pin plug, pin 5
Power Lock blue/green - driver kick or SJB, gray 26 pin plug (C), pin 17
Power Unlock yellow/purple - driver kick or SJB, gray 26 pin plug (C), pin 4
Notes: The inertia fuel shutoff switch is in the driver kick.
Lock Motor gray/brown 5 wire driver kick or SJB, black 32 pin plug (D), pin 6
Unlock Motor blue/green 5 wire driver kick or SJB, black 32 pin plug (D), pin 28
Parking Lights+ PURPLE / white + SJB, gray 13 pin plug (E), pin 6
Parking Lights- gray - headlight switch or SJB, black 52 pin plug (B), pin 31
May need to interrupt the headlight switch ground when triggering this wire. It is BLACK/ purple at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Hazards BROWN / yellow - hazard switch or SJB, black 52 pin plug (B), pin 48
Turn Signal(L) blue/green (F) + SJB, black 26 pin plug (F), pin 21
The rear turn signals are gray/brown, BROWN / purple, and WHITE/ green at the BCM B, black 24 pin plug, pins 4, 3, and 2.
The BCM B (Body Control Module B) is in the right side of the cargo compartment.
Turn Signal(R) yellow/purple (F) + SJB, black 26 pin plug (F), pin 23
The rear turn signals are PURPLE / orange, brown, and gray/purple at the BCM B, black 24 pin plug, pins 16, 15, and 14.
Reverse Light GREEN/ brown + BCM B, black 24 pin plug, pin 5
Notes: The BCM B (Body Control Module B) is in the right side of the cargo compartment.
On vehicles with auto-dimming rearview mirror, can also use gray/brown (+) in the passenger kick, harness to rear.
Door Trigger GREEN/ purple - N.C. driver kick or SJB, gray 26 pin plug (C), pin 14
Dome Supervision gray/purple + SJB, gray 14 pin plug (A), pin 9
Trunk/Hatch Pin gray/orange - N.C. SJB, gray 26 pin plug (C), pin 16
Hood Pin blue/orange - N.C. hood switch or SJB, black 26 pin plug (F), pin 10
Trunk/Hatch Release brn/yel (coupe), brn/yel or brn/pur (convertible) - release switch or SJB, gray 26 pin plug (C), pin 20
Power Sliding Door N/A
Factory Alarm Arm yellow/gray (driver door key lock) - driver kick or SJB, gray 26 pin plug (C), pin 9
Factory Alarm Disarm GREEN/ purple (driver door key unlock) - driver kick or SJB, gray 26 pin plug (C), pin 8
Disarm No Unlock see factory alarm disarm
Tachometer gn/bu, gy/ye, pu/gy, ye/og, bn, gn/wh, gy/bn, pu/o ac any fuel injector, black (V6) or gray (V8) 2 pin plug, pin 1
Wait to start N/A
Brake Wire PURPLE / white + brake switch or SJB, black 52 pin plug (B), pin 40
Parking Brake WHITE/ purple - parking brake switch or SJB, gray 26 pin plug (C), pin 1
Horn Trigger blue/white - horn switch or SJB, black 52 pin plug (B), pin 41
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Modules: Not Available
