2013 Chevrolet Malibu Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133721
Printed Date: April 28, 2024 at 9:56 PM
Topic: 2013 Chevrolet Malibu Alarm/Remote Start Wiring
Posted By: chevyhhrss400
Subject: 2013 Chevrolet Malibu Alarm/Remote Start Wiring
Date Posted: February 27, 2013 at 11:26 PM
Looking for wiring info for alarm/remote start
And audio system info
Car has remote start so just was better alarm added
Car came with chevy new myLink system
Can it be wired for dvd video playback?
Want to add back up camera also
And add amplifier to stock headunit. Its not premium setup though
Date Posted: February 28, 2013 at 9:43 AM
Noone has schematic in this vehicle?
Posted By: wirewise
Date Posted: June 03, 2013 at 9:56 AM
2013 CHEVROLET MALIBU 4DR SEDAN WITH 2.0L T/C ENGINE AND STANDARD 6-SPEAKER AUDIO SYSTEM
Security
WIRE COLOR POLARITY LOCATION
Battery RED / BLUE (+) IGNITION SWITCH HARNESS
Ignition 1 VIOLET (+) IGNITION SWITCH HARNESS
Starter 1 GREEN/ YELLOW (+) AT KEYLESS ENTRY MODULE HIGH IN PASSENGER KICKPANEL TO RIGHT OF GLOVEBOX
All Door Trigger GRAY (+) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Domelight Super GRAY (+) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
LF Latch GRAY (-) IN HARNESS AT DOOR LATCH IN DOOR
RF Latch GRAY (-) IN HARNESS AT DOOR LATCH IN DOOR
LR Latch BROWN / WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
RR Latch GRAY/BLACK (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Trunk Trigger VIOLET (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Hood Trigger BROWN / GREEN (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Alarm Disarm BLUE/VIOLET (-) IN HARNESS AT DOOR LATCH IN FRONT LEFT DOOR
PULSE THIS WIRE TO INDICATE THE KEY BEING PRESENT IN THE DRIVERS DOOR TO TEMPORARILY DISARM THE FACTORY ALARM.
Alarm Arm
PULSE THE LOCK WIRE TWICE TO ARM THE FACTORY ALARM.
Parking Lights GRAY (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Convenience
Headlights-Lo WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Headlights-Hi WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
LF Pk Lt Bulb VIOLET/GRAY (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb GRAY/BROWN (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb VIOLET/GRAY (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb GRAY/BROWN (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights GREEN / WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
LF Hazrd Bulb BLUE/WHITE (+) AT FRONT LEFT DIRECTIONAL LIGHT
RF Hazrd Bulb GREEN/ VIOLET (+) AT FRONT RIGHT DIRECTIONAL LIGHT
LR Hazrd Bulb BLUE/WHITE (+) AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb BLUE/VIOLET (+) AT REAR RIGHT DIRECTIONAL LIGHT
Wipers-Lo BLACK (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Wipers-Hi GRAY (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Parking Brake BLUE/VIOLET (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Trnk Release YELLOW/BLUE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Remote Start
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Neutral Safety WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Brake Lights VIOLET/WHITE (+) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
DO NOT USE THE WIRE(S) AT THE SWITCH ABOVE THE PEDAL AS THIS WILL AFFECT VEHICLE DYNAMICS CONTROLS.
Reverse Lights GREEN / WHITE (+) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Horn GREEN (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Databus GREEN/ VIOLET (DATA) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Rear Defrost BROWN / VIOLET (+) IN HARNESS AT HVAC CONTROL MODULE AT REAR OF HVAC CONTROLS
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
PowerLock BROWN (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
Driver Mtr Unlock GRAY (REV) AT MOTOR IN DOOR
Driver Mtr Lock BROWN / YELLOW (REV) AT MOTOR IN DOOR
Pas Mtr Unlock GRAY (REV) AT MOTOR IN DOOR
Pas Mtr Lock BROWN / YELLOW (REV) AT MOTOR IN DOOR
LF Window Up GREEN/ GRAY OR GREEN / WHITE (REV) AT MOTOR IN DOOR
LF Window Dn YELLOW/VIOLET OR GRAY (REV) AT MOTOR IN DOOR
RF Window Up GREEN/ GRAY (REV) AT MOTOR IN DOOR
RF Window Dn YELLOW/BLUE (REV) AT MOTOR IN DOOR
LR Window Up BLUE/VIOLET (REV) AT MOTOR IN DOOR
LR Window Dn YELLOW/BLUE (REV) AT MOTOR IN DOOR
RR Window Up BLUE/GRAY (REV) AT MOTOR IN DOOR
RR Window Dn GREEN/ BLACK (REV) AT MOTOR IN DOOR
Sunroof Open BLUE/VIOLET (-) AT SUNROOF MOTOR ASSEMBLY ABOVE HEADLINER
PULSE GROUND THROUGH A 98-OHM RESISTOR.
Sunroof Close BLUE/VIOLET (-) AT SUNROOF MOTOR ASSEMBLY ABOVE HEADLINER
PULSE GROUND THROUGH AN 830-OHM RESISTOR.
