2012 camry ignition hot/sense wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134024
Printed Date: May 16, 2024 at 3:08 AM
Topic: 2012 camry ignition hot/sense wire
Posted By: skidatyl
Subject: 2012 camry ignition hot/sense wire
Date Posted: April 12, 2013 at 2:02 PM
Hello all, I have 2012 Camry with a push button start switch and I am wanting to install a GPS tracker only three wire hook up 12V+,Ground,12v+ ignition sense. My question is where can I locate the 12V ignition sense wire. I am comfident that I can find the 12V+ all the time wire and the ground just not sure about the 12v only when the key is on source.( because it dont have a key) just the momentary push button. Any help would be greatly appreciated.
Skidatyl
Posted By: i am an idiot
Date Posted: April 12, 2013 at 9:10 PM
Grey wire on the Radio harness is an Accessory wire. It will be hot with ignition and when the key is in the Acc position.
Posted By: tonanzith
Date Posted: April 12, 2013 at 9:58 PM
it is also a black wire in the driver kick panel driver kick, gray 20 pin plug, pin 11
or a pink wire behind the fuse box dash fuse box, rear, white 56 pin plug (3A), pin 27
------------- Gary Sather
Posted By: skidatyl
Date Posted: April 15, 2013 at 9:42 PM
Thanks guys for the replies. tTe GPS unit is supposed to arrive Thursday. I think I will try to locate the wire in the kick panel or the one behind the fuse panel the installation manual said to try to avoid using the radio wires because of possible noise issues.
Posted By: skidatyl
Date Posted: April 19, 2013 at 11:18 AM
Ok my unit came in and I am ready for the install. I was wondering if there was an always hot and a ground wire available in the gray 20 pin plug or the white 56 pin plug that tonanzith mentioned? iI would make the install go alot easier and cleaner if there was.
Ski
Date Posted: April 19, 2013 at 11:54 AM
The only constant I know for sure us a LARGE white wire on the fuse box.
Always run a new ground. ------------- Gary Sather
Posted By: skidatyl
Date Posted: April 19, 2013 at 12:51 PM
Thanks for the quick reply tonanzith. Where is the pink wire behind the fuse box dash fuse box, rear, white 56 pin plug (3A), pin 27 in relationship to the above mentioned white hot wire?
Date Posted: April 19, 2013 at 2:14 PM
on the opposite side that the fuses are on.. should be rear facing the firewall. kind of a pain to get to. there is also a black ignition wire in the driver kick panel.
