2013 Jeep Wrangler Unlimited Alarm/Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134179
Printed Date: April 28, 2024 at 1:13 AM
Topic: 2013 Jeep Wrangler Unlimited Alarm/Stereo Wiring
Posted By: bc0351
Subject: 2013 Jeep Wrangler Unlimited Alarm/Stereo Wiring
Date Posted: May 08, 2013 at 10:13 PM
Looking for 2013 Jeep Wrangler Unlimited Wiring Diagram.
Posted By: tonanzith
Date Posted: May 11, 2013 at 12:01 PM
12 Volts red + battery or underhood fuse box
Second 12 Volts lt. blue/red (10A) + ignition switch, black 5 pin plug, pin 5
Starter yellow/gray (for starter kill only) + starter or underhood fuse box, blue 26 pin plug, pin 8
Second Starter PURPLE / brown (use interface mod or Tech Doc 1084) - 180 ohms ignition switch, black 5 pin plug, pin 2
Ignition pink/white + ignition switch, black 5 pin plug, pin 3
Second Ignition N/A
Third Ignition N/A
Accessory same as second starter - 560 ohms
Second Accessory N/A
Third Accessory N/A
Keysense same as second starter -8.5K ohms
Data Bus N/A
Can Bus High WHITE/ black (CAN C bus) data SKREEM around ignition switch, black 8 pin plug, pin 6
The CAN IHS bus high is WHITE/ gray at the instrument cluster, brown 20 pin plug, pin 16.
Can Bus Low WHITE/ lt. blue (CAN C bus) data SKREEM around ignition switch, black 8 pin plug, pin 7
The CAN IHS bus low is WHITE/ orange at the instrument cluster, brown 20 pin plug, pin 15.
Can Bus Sw N/A
Power Lock PURPLE / lt. green -1000 ohms driver kick, door harness, black 14 pin plug, pin 5
Power Unlock same as power lock - 249 ohms
Lock Motor tan/white 5 wire driver kick, door harness, black 14 pin plug, pin 8
Driver Unlock Motor tan/lt. green 5 wire driver kick, door harness, black 14 pin plug, pin 1
Passenger Unlock Motor tan/brown 5 wire passenger kick, door harness, black 14 pin plug, pin 8
Parking Lights (-) (LIN bus)
Parking Lights (+) WHITE/ orange (L), WHITE/ purple (R) + passenger kick, harness to rear
Hazards WHITE/ dk. blue - hazard switch, black 8 pin plug, pin 1
Turn Signal (Left) WHITE/ lt. green (F); WHITE/ dk. green (R) + turn signal light (F); passenger kick, harness to rear (R)
Turn Signal (Right) WHITE/ tan (F); WHITE/ yellow (R) + turn signal light (F); passenger kick, harness to rear (R)
Headlight WHITE/ dk. blue (L), WHITE/ orange (R) + headlights or underhood fuse box, green 26 pin plug, pins 3 and 11
AutoLights N/A
Reverse Light WHITE/ gray + passenger kick, harness to rear
Left Front Door Trigger purple - driver kick, door harness, black 14 pin plug, pin 4
Right Front Door Trigger PURPLE / white - passenger kick, door harness, blk 14 pin plg, pin4
Left Rear Door Trigger PURPLE / gray - passenger kick, harness to rear
Right Rear Door Trigger purple / YELLOW - passenger kick, harness to rear
Dome Supervision yellow/white + underdash light or passenger kick, harness to rear
Trunk/Hatch Pin PURPLE / orange - passenger kick, harness to rear
Rear Glass Pin N/A
Hood Pin PURPLE / lt. blue - hood switch or underhood fuse box, gray 16 pin plug, pin 3
Trunk/Hatch Release N/A
Trunk Release Motor lt. GREEN / WHITE (unlock only) 5 wire passenger kick, harness to rear
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm see disarm no unlock
Disarm No Unlock Sentry Key, ignition, and keysense
Trunk Alarm Shunt N/A
Tachometer bn/yl, bn/dk bu, bn/lt bu, bn/tn, bn/og, or bn/pu ac any fuel injector, black 2 pin plug, pin 2
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal yellow/orange - clutch switch under hood, black 3 pin plug, pin 2
May need to interrupt dk. GREEN/ orange, pin 1 of the clutch switch during remote start to avoid check engine light.
Fuel Pump dk. blue/orange + underhood fuse box, brown 40 pin plug, pin 10
Rear Defroster dk. blue/white + latched passenger kick, harness to rear
Mirror Defroster same as rear defroster
Left Front Heated Seat (LIN bus)
Right Front Heated Seat (LIN bus)
Speed Sense (wheel speed sensor)
Brake Wire WHITE/ tan + brake switch, gray 6 pin plug, pin 6
Parking Brake dk. GREEN / WHITE - parking brake switch, black 1 pin plug, pin 1
Horn Trigger gray / YELLOW + horn or underhood fuse box, green 26 pin plug, pin 18
Wipers BROWN / lt. blue (L), BROWN / orange (H) + wiper mtr or underhood fuse box, brown 40 pin plug, pins 12 and 11
Left Front Window (Up/Down) lt. blue - white A front power window switch, black 14 pin plug, pins 14 and 13
Right Front Window (Up/Down) BROWN / lt. blue - PURPLE / white A front power window switch, black 14 pin plug, pins 7 and 3
Left Rear Window (Up/Down) ORANGE / white - ORANGE / gray A front power window switch, black 14 pin plug, pins 8 and 9
Right Rear Window (Up/Down) ORANGE / lt. blue - ORANGE / dk. blue A front power window switch, black 14 pin plug, pins 1 and 2
Sun Roof (Open/Close) N/A
Sun Roof (Limit/Close) N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12V yellow/red + radio, gray 22 pin plug, pin 1
Radio Ground black - radio, gray 22 pin plug, pin 12
Radio Ignition (CAN IHS bus)
Radio Illumination (CAN IHS bus)
Factory Amp Turn-on (CAN IHS bus)
Power Antenna N/A
Left Front Speaker (+/-) gray/purple - gray / YELLOW +,- radio, gray 22 pin plug, pins 21 and 22
On models with amplifier, the speaker wires are gray/purple - gray / YELLOW at the amplifier under driver dash, black 16 pin plug, pins 8 and 16. The tweeter wires are gray/orange - gray / YELLOW at the amplifier, white 22 pin plug, pins 20 and 9.
Right Front Speaker (+/-) dk. GREEN/ purple - dk. GREEN/ YELLOW +,- radio, gray 22 pin plug, pins 19 and 20
On models with amplifier, the speaker wires are dk. GREEN/ purple - dk. GREEN/ YELLOW at the amplifier under driver dash, black 16 pin plug, pins 7 and 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 and 8.
Left Rear Speaker (+/-) gray/lt. green - gray/dk. green +,- radio, gray 22 pin plug, pins 8 and 9
On models with amplifier, the speaker wires are gray/lt. green - gray/dk. green at the amplifier under driver dash, black 16 pin plug, pins 13 and 5.
Right Rear Speaker (+/-) dk. GREEN/ lt. green - dk. GREEN/ gray +,- radio, gray 22 pin plug, pins 10 and 11
On models with amplifier, the speaker wires are dk. GREEN/ lt. green - dk. GREEN/ gray at the amplifier under driver dash, black 16 pin plug, pins 4 and 12.
Center Channel (+/-) N/A
Subwoofer (+/-) gry/brn - dk grn/brn (1); gry/wht - dk grn/wht (2) +,- amplifier under driver dash, blk 16 pin plug, pins 14 and 6; 3 and 11
Aux. Audio Input Left (+/-) dk. GREEN/ orange - dk. green (hands free audio) +,- radio, gray 10 pin plug, pins 1 and 6
Aux. Audio Input Right (+/-) dk. GREEN/ YELLOW - dk. green (hands free audio) +,- radio, gray 10 pin plug, pins 2 and 6
RSE Video (+/-) N/A
RSE Audio Left (+/-) N/A
RSE Audio Right (+/-) N/A
Satellite Radio 12 Volts N/A
Satellite Radio Ground N/A
Satellite Radio Ignition N/A
Satellite Radio Antenna N/A
Satellite Audio Left (+/-) N/A
Satellite Audio Right (+/-) N/A
Item Size Depth Location
Headunit double DIN center of dash
Left Front Speaker 6.5 left front dash
Left Front Tweeter 0.75 left front dash
Right Front Speaker 6.5 right front dash
Right Front Tweeter 0.75 right front dash
Left Rear Speaker 6.5 left rear roof
Left Rear Tweeter N/A
Right Rear Speaker 6.5 right rear roof
Right Rear Tweeter N/A
Center Channel N/A
Subwoofer 8 right rear quarter panel
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner (built into radio)
------------- Gary Sather
Posted By: txjeep
Date Posted: January 30, 2015 at 12:44 AM
very helpful. looks like a copy/paste so you may not know the answer, but is the WHITE/ gray wire on the driver kick the same as the WHITE/ gray on the passenger kick? (reverse wire)?
Posted By: howie ll
Date Posted: January 30, 2015 at 7:24 AM
TXJEEP. I'm not sure whether you're being facetious or just ignorant.
TONANZITH has taken the pains to cut, paste and download this in his own time for the OP.
The whole idea of "crib sheets" as seen by a pro or experienced amateur is to TEST & VERIFY for themselves.
That of course is also the answer to the question in your last line.
Posted By: txjeep
Date Posted: January 30, 2015 at 10:01 AM
Thanks Howie, I'll have to admit it's definitely the latter. My apologies to TONANZITH. I suppose I'm new around here and made an assumption that clearly wasn't right. Reason I thought so was on some of the other forums I'm on, some posters have access to detailed info like DTC codes and they post up all the detail by copying from their source. I mistakenly thought this was potentially the same sort of thing.
And thanks for replying to my ignorance and setting me straight, on other forums I would have been branded a troll and ignored forever. I clearly have a lot to learn!
Posted By: howie ll
Date Posted: February 01, 2015 at 3:28 AM
No problems. There are certain sites that are only open to registered dealers. We often download from there to help others. If we get found out we can loose that access.
There are lots of North American market vehicles that we in Europe never see but looking at the install guide we get a good idea.
Posted By: txjeep
Date Posted: February 18, 2015 at 12:34 AM
Decided it was worthwhile to buy a nice clamp-on multi-meter and figure out the answer myself. In case anyone comes across the post with the same question I posted above, the white wire w/ gray stripe behind the driver kick is the same reverse wire.
Posted By: howie ll
Date Posted: February 18, 2015 at 4:02 AM
Nice, thanks for posting the info.
