2010 tundra door sill wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134319
Printed Date: May 21, 2024 at 9:13 PM
Topic: 2010 tundra door sill wires
Posted By: avand1979
Subject: 2010 tundra door sill wires
Date Posted: June 06, 2013 at 4:28 AM
I'm hooking up actuators in the tailgate so I can open my tailgate with key fob. I have a TR-7 and a relay and I need to know a 12v constant and the lock/unlock wires in the passenger door sill and what colors they are. Has anyone done this before?
Posted By: howie ll
Date Posted: June 06, 2013 at 5:18 AM
Look in the vehicle wiring section here.
Date Posted: June 06, 2013 at 6:28 AM
Can't find it
Date Posted: June 06, 2013 at 6:32 AM
I found it, but need passenger side
Posted By: howie ll
Date Posted: June 06, 2013 at 6:46 AM
If you can lock and unlock all the doors from the passenger front door, it will be there, TEST. Otherwise you'll have to go to the driver's side.
Posted By: kreg357
Date Posted: June 06, 2013 at 7:13 AM
Never tried finding those wires in the passenger kick or door sill area. They are real easy to
find in the Drivers Kick Panel. There, it is a 17 Pin Blue Plug as follows :
Lock (-) White @ Pin 7
Unlock (-) Red @ Pin 6
Factory Alarm Arm (-) Light Blue @ Pin 14
Factory Alarm Disarm ( - double pulse) Pink @ Pin 16
You could check in the PKP for these wires as Toyota usually has some in there.
I usually grab the +12V constant at the thick Black wire at the fuse box.
------------- Soldering is fun!
Date Posted: June 06, 2013 at 10:13 AM
I figured it out thanks for the help.
