2013 Toyota Tacoma Alarm/Remote Start/Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134350
Printed Date: May 01, 2024 at 1:39 AM
Topic: 2013 Toyota Tacoma Alarm/Remote Start/Stereo Wiring
Posted By: ghost1024
Subject: 2013 Toyota Tacoma Alarm/Remote Start/Stereo Wiring
Date Posted: June 11, 2013 at 7:12 AM
Looking for Alarm/Remote start wire diagram for a 2013 Tacoma.
Posted By: wirewise
Date Posted: June 11, 2013 at 12:22 PM
2013 TOYOTA TACOMA 2DR TRUCK WITH 2.7L ENGINE AND STANDARD 4-SPEAKER AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery LIGHT BLUE (+) RADIO HARNESS
Accessory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
LF Speaker (+) PINK
THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
RF Speaker (-) BLUE
Steering Cntrls YES
Speed Cntrl NO
Radio Security YES
Security
Battery WHITE/ BLUE & WHITE/ RED (+) IGNITION SWITCH HARNESS
Ignition 1 BLUE / YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger GREEN / WHITE (-) MAIN BODY ECU
Domelight Super BLUE (-) UNDER DASH FUSEBOX
LF Latch GREEN/ YELLOW (-) UNDER DASH FUSEBOX
RF Latch RED / BLACK (-) UNDER DASH FUSEBOX
Alarm Disarm GREEN/ BLACK & WHITE/ RED (-) MAIN BODY ECU
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER, USE DOUBLE PULSE TO UNLOCK ALL DOORS, CAN ALSO USE KEYSENSE WIRE FOR DISARM NO UNLOCK
Alarm Arm VIOLET (-) VEHICLE FUSEBOX
Parking Lights GREEN (+) UNDER DASH FUSEBOX
Low Crr Pk Lights GREEN (-) AT VEHICLE HEADLIGHT SWITCH
ALSO AT MAIN BODY ECU PIN 13
Convenience
Headlights-Lo PINK (-) AT VEHICLE LIGHT SWITCH
Headlights-Hi RED / GREEN (-) AT VEHICLE LIGHT SWITCH
LF Pk Lt Bulb GREEN (+) AT FRONT LEFT PARKING LAMP
RF Pk Lt Bulb GREEN (+) AT FRONT RIGHT PARKING LAMP
LR Pk Lt Bulb GREEN (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
RR Pk Lt Bulb GREEN (+) AT REAR RIGHT TAIL LIGHT ASSEMBLY
All Hazrd Lights RED / WHITE (-) AT HAZARD SWITCH
ALSO AT UNDER DASH FUSEBOX
LF Hazrd Bulb YELLOW (+) AT FRONT LEFT TURN SIGNAL LIGHT
RF Hazrd Bulb LIGHT BLUE (+) AT FRONT RIGHT TURN SIGNAL LIGHT
LR Hazrd Bulb YELLOW (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
RR Hazrd Bulb BLUE/WHITE (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
Wipers-Lo BLUE/BLACK (+) AT WIPER CONTROL SWITCH
Wipers-Hi BLUE/RED (+) AT WIPER CONTROL SWITCH
Parking Brake GREEN/ YELLOW (-) UNDER DASH FUSEBOX
Remote Start
Ignition 2 BLACK/ RED (+) IGNITION SWITCH HARNESS
Accessory 1 WHITE/ GREEN (+) IGNITION SWITCH HARNESS
Starter 2 GREEN/ BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense GREEN/ BLACK (-) IGNITION SWITCH HARNESS
THIS WIRE WILL ALSO DISARM THE FACTORY ALARM WITHOUT UNLOCKING THE DOORS
Tachometer BLACK/ WHITE (-) OBDII CONNECTOR
Low Crr. Pk Lights GREEN (-) AT VEHICLE HEADLIGHT SWITCH
Brake Lights BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) IN HARNESS IN DRIVER KICKPANEL
Horn GREEN/ RED (-) UNDER DASH FUSEBOX
IMO LIGHT GREEN/ BLACK (DATA) AT TRANSPONDER ECU BEHIND CLUSTER
IMI BLUE/WHITE (DATA) AT TRANSPONDER ECU BEHIND CLUSTER
Modules
WIRE LOCATION
Module 1 MAIN BODY ECU - PART OF UNDER DASH FUSEBOX
Module 2 ECM - BEHIND GLOVEBOX TO RIGHT
Module 3 ABS MODULE - UNDER HOOD NEAR DRIVER FIREWALL OR PASSENGER FENDER DEPENDING ON EQUIPMENT
Doorlocks/Windows
Power Unlock GRAY (-) VEHICLE FUSEBOX
PowerLock BLUE/WHITE (-) VEHICLE FUSEBOX
Driver Mtr Unlock BLUE/RED (REV) UNDER DASH FUSEBOX
Driver Mtr Lock BLUE/BLACK (REV) MANIN BODY ECU
LF Window Up BLUE (REV) AT WINDOW SWITCH IN DRIVER DOOR
LF Window Dn BLUE/BLACK (REV) AT WINDOW SWITCH IN DRIVER DOOR
RF Window Up BLUE / YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RF Window Dn BLACK (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Posted By: victorya
Date Posted: February 22, 2014 at 10:36 PM
I am going to install a code alarm combo unit in my 4 door limited auto Tacoma and would like to know any helpful hints. For example: is the info posted above all I need to know? Do I need relays for second starter, etc? Right now I plan to only use one relay for starter kill and one for accessory to power heated mirrors. Thanks in advance.
Posted By: harryharris
Date Posted: February 23, 2014 at 4:15 AM
You will probably need at least one since this vehicle has 2 starter wires and 2 ignitions.
------------- Test before boxing up.
Posted By: victorya
Date Posted: February 23, 2014 at 4:53 PM
Thanks very much. I appreciate the tip. Need to research how I'd wire those up.
