starter wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134437
Printed Date: May 15, 2024 at 8:11 PM
Topic: starter wiring diagram
Posted By: mench
Subject: starter wiring diagram
Date Posted: June 26, 2013 at 12:27 AM
I need a wiring diagram of the starter circuit for a 2002 Toyota Tacoma 2wd.
Thank You
Posted By: howie ll
Date Posted: July 09, 2013 at 9:03 AM
Look in the vehicle wiring section.
Posted By: howie ll
Date Posted: July 09, 2013 at 9:07 AM
Here you go:-
STARTER black+ ignition harness IGNITION BLACK/ red + ignition harness
SECOND IGNITION BLACK / YELLOW + ignition harness ACCESSORY blue/red + ignition harness
Of course that's two minutes with a DMM.
Posted By: mench
Date Posted: July 09, 2013 at 11:21 PM
I was requesting a Diagram ie. picture of the starting circuit and not words. As the old saying goes, "a picture is worth a thousand words".
Thanks anyway,
Mench
Posted By: howie ll
Date Posted: July 10, 2013 at 12:42 AM
Why?
Posted By: 91stt
What are you trying to do?
------------- This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Posted By: Ween
Date Posted: July 10, 2013 at 6:11 AM
https://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f80378d17
scroll down, look under charging...starting is on the left side of the image.
mark
