sport trac 05 door trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135326
Printed Date: May 29, 2024 at 5:38 AM
Topic: sport trac 05 door trigger
Posted By: elchicolino1
Subject: sport trac 05 door trigger
Date Posted: November 19, 2013 at 11:00 AM
Anyone done this truck before I can't find the wire for drivers door trigger (yellow/black does not work ) any ideas?
Posted By: Velocity Motors
Date Posted: November 19, 2013 at 7:19 PM
All Doors BLACK/ LIGHT BLUE (+) IN HARNESS IN DRIVERS KICKPANEL OR COURTESY LIGHT UNDER DASH
Front Left Door YELLOW/BLACK (+) IN HARNESS IN DRIVERS KICKPANEL
Front Right Door GRAY/RED (+) IN HARNESS IN DRIVERS KICKPANEL
Rear Left Door LIGHT GREEN/ YELLOW (+) IN HARNESS IN DRIVERS KICKPANEL
Rear Right Door PINK/LIGHT BLUE (+) IN HARNESS IN DRIVERS KICKPANEL
If the BCM has power saving on it, then you must diode isolate and relay isolate the triggers. Test first before proceeding to the isolation stage.
------------- Jeff
Date Posted: November 19, 2013 at 8:04 PM
I found the wire drivers door trigger
yellow/black (-) on drivers kick harness grey connector...( I was testing the yellow/ black on lower part of kickpanel to rear of vehicle) other wires found here lock/unlock and dome light but this YELLOW/BLACK shows (-) all the time
THANKS FOR THE HELP
