2013 chevrolet hd 3500 pick up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135327
Printed Date: May 18, 2024 at 9:06 AM
Topic: 2013 chevrolet hd 3500 pick up
Posted By: eslinst
Subject: 2013 chevrolet hd 3500 pick up
Date Posted: November 19, 2013 at 12:03 PM
I need the wiring for alarm/remote start, thank you in advance.
Posted By: Velocity Motors
Date Posted: November 19, 2013 at 7:09 PM
If you use iDatalink modules, it gives you all the necessary wires and locations for RS and security interface. Here's the information for the truck:
Battery RED / BLACK (+) VEHICLE INTERIOR FUSE BOX LOW CURRENT, FOR HIGH CURRENT USE RED / BLACK AT VEHICLE FUSE BOX
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Ignition 2 WHITE (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN OR YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW/BLACK (+) AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT NOT FOR REMOTE START, *SEE DOCUMENTS FOR REMOTE START INFORMATION
Starter 2 WHITE (+) IGNITION SWITCH HARNESS USE A 1.3K OHM RESISTOR FOR START, **SEE DOCUMENTS FOR REMOTE START INTEGRATION
Key Sense PINK/BLACK OR PINK (+) IGNITION SWITCH HARNESS
All Doors GRAY/BLACK (+) AT BCM MODULE UNDER DRIVER SIDE DASH MAY BE GRAY ON SOME MODELS, TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
Front Left Door GRAY/BLACK (-) AT MODULE IN DRIVER DOOR MAY BE BROWN ON SOME MODELS
Front Right Door TAN/WHITE (-) AT MODULE IN PASSENGER DOOR MAY BE BLACK/ WHITE ON SOME MODELS
Rear Left Door LIGHT BLUE/BLACK (-) AT BCM MODULE UNDER DRIVER DASH PINK PLUG PIN #15
Rear Right Door LIGHT GREEN/ BLACK (-) AT BCM MODULE UNDER DRIVER DASH PINK PLUG PIN #14
Dome Light Supervision GRAY (+) AT BCM MODULE UNDER DRIVER DASH
Dome Light 1 GRAY (+) IN HARNESS AT VEHICLE DOMELIGHT
Hood Trigger PINK/BLACK (-) AT BCM MODULE UNDER DRIVER DASH BLACK PLUG PIN #17, NOT ON ALL MODELS
All Parking Lights LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH
Front Left Parking Light BROWN (+) AT FRONT LEFT PARKING LIGHT
Front Right Parking Light BROWN (+) AT FRONT RIGHT PARKING LIGHT
Rear Left Parking Light BROWN (+) AT REAR LEFT PARKING LIGHT
Rear Right Parking Light BROWN (+) AT REAR RIGHT PARKING LIGHT
All Hazard Lights WHITE (-) AT VEHICLE HAZARD SWITCH
Low Beam Headlights WHITE (-) AT VEHICLE HEADLIGHT SWITCH
Brake Lights LIGHT BLUE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL IGNITION MUST BE ON FOR THIS WIRE TO TEST
Reverse Lights DARK BLUE (+) AT BCM MODULE UNDER DRIVER DASH
Power Lock LIGHT BLUE (+) AT BCM MODULE UNDER DRIVERS SIDE OF DASH THIS WIRE LOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
Power Unlock WHITE (-) AT BCM MODULE UNDER DRIVERS SIDE OF DASH THIS WIRE UNLOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
Driver Door Motor 1 TAN (REV) AT MOTOR IN DOOR
Driver Door Motor 2 VIOLET (REV) AT MOTOR IN DOOR
Passenger Door Motor 1 TAN (REV) AT MOTOR IN DOOR
Passenger Door Motor 2 GRAY/BLACK (REV) AT MOTOR IN DOOR
Factory Alarm Disarm LIGHT GREEN (-) AT MODULE IN DRIVERS DOOR
Horn TAN (-) IN HARNESS AT STEERING COLUMN ALSO AT BCM MODULE UNDER DRIVER DASH
Parking Brake LIGHT BLUE (-) AT VEHICLE PARKING BRAKE SWITCH
Front Left Window Up DARK BLUE (REV) DRIVER DOOR MODULE IN DRIVER DOOR
Front Left Window Down BROWN (REV) DRIVER DOOR MODULE IN DRIVER DOOR
Front Right Window Up DARK BLUE (REV) PASSENGER DOOR MODULE IN PASSENGER DOOR
Front Right Window Down BROWN (REV) PASSENGER DOOR MODULE IN PASSENGER DOOR
Rear Left Window Up DARK BLUE (REV) AT WINDOW SWITCH IN REAR LEFT DOOR
Rear Left Window Down BROWN (REV) AT WINDOW SWITCH IN REAR LEFT DOOR
Rear Right Window Up DARK BLUE (REV) AT WINDOW SWITCH IN REAR RIGHT DOOR
Rear Right Window Down BROWN (REV) AT WINDOW SWITCH IN REAR RIGHT DOOR
Driver Seat Memory 1 ORANGE (+) AT DRIVER DOOR MODULE USE 2.2K OHM RESISTOR FOR DRIVER SEAT MEMORY 1
Driver Seat Memory 2 ORANGE (+) AT DRIVER DOOR MODULE SAME WIRE AS DRIVER SEAT MOMORY 1, USE A 4.2K OHM RESISTOR FOR SEAT MEMORY 2
Low Speed Wipers GRAY (+) AT BCM MODULE UNDER DRIVER
Tach WHITE (-) AT IGNITION COIL
------------- Jeff
Posted By: eslinst
Date Posted: November 19, 2013 at 9:03 PM
Thank you for your help, I really appreciate it.
