Print Page | Close Window |
2010 Nissan Sentra and 2012 Nissan Rogue Remote Start WiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135329 Printed Date: May 05, 2024 at 12:31 AM Topic: 2010 Nissan Sentra and 2012 Nissan Rogue Remote Start Wiring Posted By: wrsampson Subject: 2010 Nissan Sentra and 2012 Nissan Rogue Remote Start Wiring Date Posted: November 19, 2013 at 4:21 PM Hello,
I recently purchased a Bulldog remote start kit with the XK09 add-on (for the immobilizer) for my 2010 Nissan Sentra (with Smart Key) and am having a tough time with the poorly constructed diagram of where the factory wires are in the vehicle diagram they supplied. Can anyone please provide a wiring diagram for the 2010 Nissan Sentra (w/Smart Key)? Specifically, I am looking for the locations of the "Factory Alarm Disarm," "Anti-Theft," "Brake," "Tachometer," "Horn," "Trunk Release," "Domelight Supervision," "Door Trigger," "Lock Motor Wire," "Power Unlock," "Power Lock," "Parking Lights (+)," "Parking Lights (-)," and any other wires that may come to mind (as I never mind having extra information. Additionally, I did notice this forum has wiring diagrams for the 2007 Nissan Sentra and understand that often times vehicles in certain time frames can have the same factory wiring layouts-if this is the case and anyone can confirm that please let me know and I'll utilize that information in lieu of new pinout information. Thank you in advance for your help! ------------- WRS Replies: Posted By: Velocity Motors Date Posted: November 19, 2013 at 7:15 PM Battery GREEN (+) IGNITION SWITCH HARNESS
Ignition 1 YELLOW (+) IGNITION SWITCH HARNESS Accessory 1 RED (+) IGNITION SWITCH HARNESS Accessory 2 BLUE (+) IGNITION SWITCH Starter 1 WHITE (+) IGNITION SWITCH HARNESS Key Sense RED / BLUE (+) IGNITION SWITCH HARNESS **THIS WIRE MUST BE ENERGIZED DURING REMOTE START** All Doors YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS. *SEE DOCUMENTS Front Left Door LIGHT BLUE (-) IN HARNESS IN DRIVERS KICKPANEL Front Right Door BROWN / WHITE (-) IN HARNESS IN PASSENGER KICKPANEL MAY ALSO BE BROWN Rear Left Door RED / WHITE (-) IN HARNESS IN DRIVER KICKPANEL MAY ALSO BE BROWN / WHITE Rear Right Door RED / WHITE (-) IN HARNESS IN PASSENGER KICKPANEL MAY ALSO BE WHITE Dome Light Supervision RED (-) AT BCM MODULE TO RIGHT OF RADIO BEHIND DASH 63 Trunk/Hatch WHITE/ GREEN (-) IN HARNESS IN DRIVER KICKPANEL All Parking Lights RED (+) IN HARNESS IN DRIVER KICKPANEL All Hazard Lights YELLOW (-) AT VEHICLE HAZARD SWITCH Brake Lights RED / GREEN (+) AT SWITCH ABOVE BRAKE PEDAL Reverse Lights WHITE/ BLACK (+) IN HARNESS IN DRIVER KICKPANEL TO REAR Power Lock RED (-) IN HARNESS IN DRIVER KICKPANEL TO DOOR Power Unlock PINK (-) IN HARNESS IN DRIVER KICKPANEL TO DOOR Driver Door Motor 1 GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR Driver Door Motor 2 VIOLET (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR Passenger Door Motor 1 GREEN (REV) IN HARNESS IN PASSENGER KICKPANEL TO DOOR Passenger Door Motor 2 VIOLET (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR Trunk Release RED (+) IN HARNESS IN DRIVER KICKPANEL TO REAR Factory Alarm Disarm THERE IS AN OPEN PIN IN THE KEYLESS ENTRY CONNECTOR NEXT TO THE VIOLET TRUNK RELEASE WIRE, THIS WILL DISARM THE FACTORY ALARM IF EQUIPPED WITH A (-) PULSE Factory Alarm Indicator LIGHT BLUE (-) AT BCM MODULE TO RIGHT OF RADIO BEHIND DASH 23 Horn GREEN (-) IN HARNESS HIGH IN DRIVER KICKPANEL MAY ALSO BE GREEN / WHITE Parking Brake GREEN (-) AT PARKING BRAKE SWITCH ALSO GRAY IN HARNESS TO REAR OF GAUGES Low Speed Wipers BLUE (+) AT VEHICLE WIPER MOTOR High Speed Wipers BLUE/BLACK (+) AT VEHICLE WIPER MOTOR Anti-Theft Reference RED (DATA) AT IMMOBILIZER ANTENNA AMP 2 Anti-Theft Signal ORANGE (DATA) AT IMMOBILIZER ANTENNA AMP 4 Tach RED (-) AT ECM MODULE UNDER HOOD 25 Speed Sense GRAY (AC) IN HARNESS TO GAUGES 7 MAY ALSO BE BLUE/WHITE ------------- Jeff Velocity Custom Home Theater Mobile Audio/Video Specialist Morden, Manitoba CANADA Posted By: wrsampson Date Posted: November 19, 2013 at 7:52 PM Jeff,
Please allow me to extend my sincerest thanks for your help. I sincerely appreciate it. Have a great holiday. ------------- WRS Posted By: Velocity Motors Date Posted: November 19, 2013 at 8:01 PM When you have issues with the XK09 module, you can always use the iDatalink ADS-ALCA instead.
------------- Jeff Velocity Custom Home Theater Mobile Audio/Video Specialist Morden, Manitoba CANADA Posted By: wrsampson Date Posted: November 19, 2013 at 8:15 PM I did see that while doing the research, hopefully it won't come to that (for the sake of saving cash) but thank you for the heads up if I get stuck with a unit that's nonfunctional. I don't suppose you happen to have all of the same pinout/harness data I requested for the 2010 Nissan Sentra for the 2012 Regular Key (key goes into the ignition to start the vehicle) Rogue? If not, no big deal, I just know that if I succeed in installing this unit in my wife's vehicle mine will be next with these cold winters. I'm getting too old to be running out to the car to turn it on twenty minutes before I leave each morning, lol. Thanks again Jeff.
------------- WRS Posted By: Velocity Motors Date Posted: November 20, 2013 at 8:28 PM 2012 Nissan Rogue:
Battery BLACK (+) IGNITION SWITCH HARNESS 5 Ignition 1 BLUE (+) IGNITION SWITCH HARNESS 8 Ignition 2 ORANGE (+) IGNITION SWITCH HARNESS 3 Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS 4 Starter 1 WHITE (+) IGNITION SWITCH HARNESS 1 Key Sense BLUE (+) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH D9 All Doors GREEN/ BLACK (-) IN HARNESS AT BACK OF GAUGE CLUSTER THIS WIRE CAN ALSO BE FOUND IN THE HARNESS AT THE OVERHEAD DOME LIGHT AS A YELLOW (-). Front Left Door RED (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH Front Right Door BLUE/ORANGE (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH Rear Left Door RED / ORANGE (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH Rear Right Door RED / ORANGE (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH Dome Light Supervision GREEN/ BLACK (-) IN HARNESS AT BACK OF GAUGE CLUSTER B1-15 Dome Light 1 RED (+) IN HARNESS AT VEHICLE DOMELIGHT 3 Dome Light 2 BLACK (-) IN HARNESS AT VEHICLE DOMELIGHT 1 Trunk/Hatch GREEN/ BLACK (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH A8 All Parking Lights ORANGE (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH A9 Front Left Parking Light GREEN/ ORANGE (+) AT FRONT LEFT PARKING LIGHT 4 Front Right Parking Light PINK (+) AT FRONT RIGHT PARKING LIGHT 4 Rear Left Parking Light PINK (+) AT REAR LEFT PARKING LIGHT 3 Rear Right Parking Light WHITE (+) AT REAR RIGHT PARKING LIGHT 3 All Hazard Lights GREEN (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH D12 Front Left Hazard Light YELLOW/ORANGE (+) AT FRONT LEFT DIRECTIONAL LIGHT 1 Front Right Hazard Light BLUE (+) AT FRONT RIGHT DIRECTIONAL LIGHT 1 Rear Left Hazard Light YELLOW/ORANGE (+) AT REAR LEFT DIRECTIONAL LIGHT 2 Rear Right Hazard Light BLUE (+) AT REAR RIGHT DIRECTIONAL LIGHT 2 Low Beam Headlights WHITE (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH D19 High Beam Headlights BROWN (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH A24 Brake Lights BLUE/ORANGE (+) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH C12 THIS WIRE CAN BE FOUND AS GRAY (+) AT SWITCH ABOVE PEDAL. Reverse Lights RED (+) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH 2 Power Lock GREEN (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH A4 Power Unlock YELLOW (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH A17 Unlock Sense BLUE (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH A15 Driver Door Motor 1 GRAY (REV) AT MOTOR IN DOOR 2 Driver Door Motor 2 GREEN (REV) AT MOTOR IN DOOR 1 Passenger Door Motor 1 GRAY (REV) AT MOTOR IN DOOR 6 Passenger Door Motor 2 GREEN (REV) AT MOTOR IN DOOR 5 Trunk Release BLUE/BLACK (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH D8 Horn RED (-) IGNITION SWITCH HARNESS R8 Parking Brake BLUE (-) IN HARNESS AT BASE OF PARKING BRAKE HANDLE UNDER CENTER CONSOLE 1 Front Left Window Up BROWN (REV) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR 7 Front Left Window Down ORANGE (REV) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR 8 Front Right Window Up ORANGE (REV) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR 14 Front Right Window Down GREEN (REV) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR 12 Rear Left Window Up BLUE (REV) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR 2 Rear Left Window Down PINK (REV) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR 1 Rear Right Window Up BROWN (REV) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR 4 Rear Right Window Down WHITE (REV) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR 3 Rear Window Defrost RED (-) AT BCM MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH D4 Rearview Mirror Ignition WHITE (+) IN HARNESS AT REARVIEW MIRROR 10 Rearview Mirror Ground BLACK (-) IN HARNESS AT REARVIEW MIRROR 8 Low Speed Wipers GREEN (-) IN HARNESS AT VEHICLE WIPER SWITCH W3 High Speed Wipers PINK (-) IN HARNESS AT VEHICLE WIPER SWITCH W9 Sunroof Battery GRAY (+) AT SUNROOF CONTROL MODULE NEAR SWITCH IN ROOF 1 Sunroof Ground BLACK (-) AT SUNROOF CONTROL MODULE NEAR SWITCH IN ROOF 2 Sunroof Vent Open YELLOW (-) AT SUNROOF CONTROL MODULE NEAR SWITCH IN ROOF 5 Sunroof Vent Close BLUE (-) AT SUNROOF CONTROL MODULE NEAR SWITCH IN ROOF 8 Sunroof Full Open GRAY (-) AT SUNROOF CONTROL MODULE NEAR SWITCH IN ROOF 4 Sunroof Full Close BLUE (-) AT SUNROOF CONTROL MODULE NEAR SWITCH IN ROOF 8 Anti-Theft Reference BLACK (-) AT IMMOBILIZER CONTROL UNIT BEHIND DASH NEAR IGNITION CYLINDER 3 Anti-Theft RX PINK (+) AT IMMOBILIZER CONTROL UNIT BEHIND DASH NEAR IGNITION CYLINDER 1 Anti-Theft TX WHITE (-) AT IMMOBILIZER CONTROL UNIT BEHIND DASH NEAR IGNITION CYLINDER 2 Databus BLUE/BLACK (DATA) AT IMMOBILIZER CONTROL UNIT BEHIND DASH NEAR IGNITION CYLINDER 5 Tach BLUE/RED (AC) IN HARNESS AT REAR OF GAUGE CLUSTER A1-3 THIS WIRE CAN ALSO BE FOUND AS BLUE ((AC) PIN #K86)) AT PCM MODULE BETWEEN AIR CLEANER HOUSING AND FUSE BOX UNDER HOOD. ------------- Jeff Velocity Custom Home Theater Mobile Audio/Video Specialist Morden, Manitoba CANADA |
