2014 silverado
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135516
Printed Date: May 02, 2024 at 6:56 AM
Topic: 2014 silverado
Posted By: JMIELITZ
Subject: 2014 silverado
Date Posted: December 11, 2013 at 12:58 PM
trying to hook up a power tailgate lock to the door lock system on 2014silverado using two standard automotive relays 85 side of the coil to the battery and the 86 to the brn / YELLOW for the lock and blu/white for the unlock relay and when hooked up i shut down the door lock system,can anyone help?
Posted By: i am an idiot
Date Posted: December 11, 2013 at 9:11 PM
You may have to run 2 wires into the door and catch the wires at the Actuator.
Posted By: JMIELITZ
Date Posted: December 16, 2013 at 10:45 AM
we have looked at that but gm has put a connector at the door jam i am just looking to put two relays under the dash to work off the door lock system appear to be some changes in the 2014 1500 door locks
Posted By: trub
Date Posted: April 08, 2014 at 6:42 PM
Jmielitz,
Did you ever get this figured out? I would like to do the same. What parts and how did you connect to the mechanism to actuate the lock? I looked, but had no good ideas for doing this.
Posted By: theaaronsway
Date Posted: August 11, 2014 at 10:53 PM
I would tap on the the door unlock and lock wires
Unlock brown /white
Lock BROWN / yellow These are negative polarity so use relay it your door latch it a positive trigger
------------- The Aaron's way
