2010 vw jetta diesel wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136047
Printed Date: May 11, 2024 at 10:59 AM
Topic: 2010 vw jetta diesel wiring
Posted By: smax12
Subject: 2010 vw jetta diesel wiring
Date Posted: February 11, 2014 at 10:22 AM
Does anyone have directwire wiring diagram for 2010 jetta diesel with heated seats,sunroof and door connections?
thank you,
max
Posted By: daflipcyde
Date Posted: February 14, 2014 at 6:52 AM
https://readyremote.com/main.asp?action=select&yr=26299&product=Remote Start&make=Volkswagen&model=Jetta
Posted By: smax12
Date Posted: February 14, 2014 at 2:51 PM
thank you,
does anyone have any info on the seats,power windows and moonroof also? want to connect them as aux ch.
thank you,
M
Date Posted: February 14, 2014 at 4:14 PM
If you get dball2 it will control windows up and down.
Left Front Window (Up/Down) use factory alarm arm/disarm
Right Front Window (Up/Down) see left front window
Left Rear Window (Up/Down) see left front window
Right Rear Window (Up/Down) see left front window
Sun Roof (Open/Close) use factory alarm arm/disarm
Sun Roof (Limit/Close) N/A
Memory Seat 1 blue / YELLOW + resistor Memory Seat Control Module, 26 pin plug, pin 13
Memory Seat 2 same as memory seat 1 + resistor
Memory Seat 3 blue/green + resistor Memory Seat Control Module, 26 pin plug, pin 8
