2014 Toyota Highlander Limited Alarm/RS Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136354
Printed Date: April 28, 2024 at 10:48 PM
Topic: 2014 Toyota Highlander Limited Alarm/RS Wiring
Posted By: milgrad
Subject: 2014 Toyota Highlander Limited Alarm/RS Wiring
Date Posted: March 29, 2014 at 6:13 AM
Does anybody having the wiring details for a 2014 Toyota Highlander Limited (push button start)?
Posted By: wirewise
Date Posted: March 29, 2014 at 6:50 AM
TOYOTA / HIGHLANDER (SMART KEY) / 2014 / Remote Start
12volts green (40A) + dash fuse box, white 1 pin plug (4L), pin 1
Starter yellow (SS1); purple (SS2) - engine start/stop switch, black 10 pin plug, pins 5, 1
Second Starter gray + left of dash fuse box, white 20 pin plug, pin 18
Ignition gray + left of dash fuse box, gray 18 pin plug, pin 12
Second Ignition N/A
Third Ignition N/A
Accessory gray + dash fuse box, rear, white 56 pin plug (4A), pin 28
Second Accessory N/A
Keysense N/A
Power Lock red (passenger door switch) - dash fuse box, rear, white 32 pin plug (4D), pin 22
Power Unlock white (passenger door switch) - dash fuse box, rear, white 32 pin plug (4D), pin 27
Lock Motor brown 5 wire driver kick, gray 18 pin plug, pin 10
Unlock Motor beige 5 wire driver kick, gray 18 pin plug, pin 18
Parking Lights+ lt. green + dash fuse box, white 32 pin plug (4F), pin 4
Parking Lights- lt. green - Body ECU on dash fuse box, white 30 pin plug, pin 22
Hazards pink - A/C control assembly, black 8 pin plug, pin 7
Turn Signal(L) green + dash fuse box, white 36 pin plug (4H), pin 7
Turn Signal(R) red + dash fuse box, white 36 pin plug (4H), pin 6
Reverse Light red + dash fuse box, white 36 pin plug (4H), pin 18
Door Trigger gray - Body ECU on dash fuse box, white 30 pin plug, pin 6
Dome Supervision lavender/white - dash fuse box, rear, white 32 pin plug (4D), pin 12
Trunk/Hatch Pin lavender / YELLOW - dash fuse box, white 36 pin plug (4H), pin 33
Hood Pin black - Body ECU on dash fuse box, white 30 pin plug, pin 11
Trunk/Hatch Release red (liftgate); green (glass) (rear handle switch) - Body ECU on dash FB, wht 30 pin plg, pin 18; wht 28 pin plg, pin 28
Notes: On models with power liftgate, the open/close is gray (-) at the power liftgate switch on dash or at the Body ECU on dash fuse box, white 28 pin plug, pin 5.
Power Sliding Door N/A
Factory Alarm Arm purple (driver door key lock) - Body ECU on dash fuse box, white 30 pin plug, pin 29
Factory Alarm Disarm lt. blue (driver door key unlock) double - Body ECU on dash fuse box, white 30 pin plug, pin 2
Disarm No Unlock (smart key and ignition)
Tachometer blue ac data link connector, white 16 pin plug, pin 9
Wait to start N/A
Brake Wire green to blue + brake switch or dash fuse box, white 36 pin plug (4H), pin 3
Parking Brake green - dash fuse box, white 32 pin plug (4F), pin 28
Horn Trigger green - dash fuse box, white 32 pin plug (4F), pin 29
Memory Seat 1 yellow - seat memory switch, white 8 pin plug, pin 4
Memory Seat 2 green - seat memory switch, white 8 pin plug, pin 3
------------- ~wirewise~
