2014 Chevrolet Impala LS Audio Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136973
Printed Date: April 29, 2024 at 9:34 AM
Topic: 2014 Chevrolet Impala LS Audio Wiring
Posted By: mc5959
Subject: 2014 Chevrolet Impala LS Audio Wiring
Date Posted: July 20, 2014 at 6:32 AM
I have been installing audio for a million years. I have never had an issue taking anything apart or tackling difficult tasks! for some reason im not sure if im getting too old or if the vehicles are just getting more complex.
I have a base model 2014 Impala with the smaller display radio, I removed as much around the display as I was comfortable with considering I could see in there pretty good yet I did not see anything that looked like an AMP.
My last resort will be to tap into the rear door speaker wires. I would much rather get it right at the module so I could even use a relay to provide me ignition source.
Anyhelp would be Greatly apprectiated!
------------- We all have decisions to make!
Posted By: i am an idiot
Date Posted: July 20, 2014 at 10:55 AM
Battery RED / PURPLE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) BLUE
LF Speaker (-) BROWN / BLUE
RF Speaker (+) YELLOW
RF Speaker (-) YELLOW/BLACK
LR Speaker (+) GREEN
LR Speaker (-) GREEN/ BLACK
RR Speaker (+) WHITE
RR Speaker (-) BLUE/BLACK
Amp Location RIGHT SIDE OF TRUNK
Steering Cntrls YES
Speed Cntrl NO
Radio Security YES
Posted By: tonanzith
Date Posted: July 20, 2014 at 4:32 PM
Left Front Speaker (+/-) blue - BROWN / blue (wfr); yel/blue - yel/gray (twt) +,- amp in trunk R side, gry 8 pin plg, pins 3-7; grn 16 pin plg, pins 5-13
Right Front Speaker (+/-) yellow - yellow/blk (wfr); brn/grn - pur/brn (twt) +,- amp in trunk R side, gry 8 pin plg, pins 2-6; grn 16 pin plg, pins 4-12
Left Rear Speaker (+/-) green - GREEN/ black +,- amplifier in trunk R side, green 16 pin plug, pins 7 - 15
Right Rear Speaker (+/-) white - blue/black +,- amplifier in trunk R side, green 16 pin plug, pins 6 - 14
Center Channel (+/-) yellow/wht - blue/yel (F); WHITE/ blk - yel/brn (R) +,- amplifier in trunk R side, green 16 pin plug, pins 3 - 11; 10 - 2
Subwoofer (+/-) blue/gray - GREEN/ blk (L); gray/blk - GREEN/ pur(R) +,- amp in trunk R side, blk 8 pin plg, pins 1-5; grn 16 pin plg, pins 8-16
Aux. Audio Input Left (+/-) gray - purple +,- radio, gray 20 pin plug, pins 9 - 8
Aux. Audio Input Right (+/-) lt. green - purple +,- radio, gray 20 pin plug, pins 10 - 8
------------- Gary Sather
Posted By: sparkie
Date Posted: July 20, 2014 at 9:10 PM
If you are working on a new design Impala's, then you can only get audio after the amp. It is in passenger side trunk. The radios on the newer GM radios is unlike anything you may have seen before. All audio and controls are multiplexed on two data lines. You cannot get anything at the radio.
------------- sparky
Date Posted: July 20, 2014 at 10:19 PM
The info I provided is wiring at the amp...
Posted By: mc5959
Date Posted: July 21, 2014 at 5:19 AM
I don't have an amp on the drivers side trunk. The passenger side looks like a bcm.
I'll doodie a pic when I pull over
This is a 2014 new body style.
Posted By: mc5959
Date Posted: July 21, 2014 at 5:37 AM
I didn't mean to write that id doodle a pic when I pulled over I was saying id upload. Didn't quite work either!
Posted By: sparkie
Date Posted: July 21, 2014 at 3:04 PM
That's the amplifier.
Posted By: mc5959
Date Posted: July 22, 2014 at 4:25 AM
I didn't have time last night to mess with it. When I first played around and pulled a plug on that module I ended up with a check engine light. I'll look again now that I have a list of wire colors.
Posted By: mc5959
Date Posted: July 22, 2014 at 6:33 AM
Thanks so much! When I first looked at the box I only saw the big bcm styl plug.
Where did you guys get the wiring info. I'm trying to find other wiring like the led drl. Trying to figure out if it's pre wired.
