2014 toyota tacoma vss speed signal wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137143
Printed Date: April 29, 2024 at 1:36 PM
Topic: 2014 toyota tacoma vss speed signal wire?
Posted By: zenbad
Subject: 2014 toyota tacoma vss speed signal wire?
Date Posted: August 23, 2014 at 11:13 AM
I'm installing an aftermarket nav unit (Pioneer 8000NEX) in a 2014 Toyota Tacoma and it is requiring an input from the speed sensor. I have searched for days but, I can't find the info for 2014 Tacomas. I have even used an O'scope to check the remaining wires on the vehicles factory radio harness but, didn't find the signal. I assumed that it would be around 7volt square waves or similar but, no luck.
The closest info to my model year is PURPLE / white wire but, there's two identical PURPLE / white wires that were going into the factory radio.
Please help!
Posted By: howie ll
Date Posted: August 23, 2014 at 1:21 PM
Test using a DMM, similar to finding tach, set to 20 VAC, black to ground and red for suspect wire which IMO SHOULD be PURPLE / white, Toyota never change colours just for the sake of it, are you listening Ford, BMW?
You should get a reading of 1 to 5-VAC as you go past 3 mph.
Or use an LED, again it should start flashing past 3 mph.
Posted By: tonanzith
Date Posted: August 31, 2014 at 1:18 PM
Speed Sense PURPLE / white ac dr kick junc box, wh 20 pin plg, pin 10, or radio, wh 28 pin plg, pin 17
------------- Gary Sather
