Print Page | Close Window |
2012 mazda 6 without push to startPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137170 Printed Date: May 02, 2024 at 5:06 AM Topic: 2012 mazda 6 without push to start Posted By: cz0f822 Subject: 2012 mazda 6 without push to start Date Posted: August 28, 2014 at 4:40 PM Requesting wiring for 2012 Mazda 6 (without push to start) remote start / alarm.
Thanks Replies: Posted By: tonanzith Date Posted: August 31, 2014 at 1:15 PM Item Wire Color Polarity Wire Location
12 Volts RED / blue (40A) + ignition switch, white 6 pin plug, pin 6 Second 12 Volts RED / black (40A) + ignition switch, white 6 pin plug, pin 3 Starter gray/red + ignition switch, white 6 pin plug, pin 1 Second Starter N/A Ignition GREEN/ YELLOW + ignition switch, white 6 pin plug, pin 2 Second Ignition N/A Third Ignition N/A Accessory pink / YELLOW + ignition switch, white 6 pin plug, pin 4 Second Accessory yellow + ignition switch, white 6 pin plug, pin 5 Third Accessory N/A Keysense RED / black + BCM in driver kick, white 30 pin plug (3), pin 27 Data Bus gray/orange (TX); WHITE/ green (RX) data PATS Transceiver around ignition key sw, white 8 pin plug, pins 4, 3 Can Bus High gray/red (HS CAN) data data link connector, black 16 pin plug, pin 6 Can Bus Low blue/red (HS CAN) data data link connector, black 16 pin plug, pin 14 Can Bus Sw N/A Power Lock BLACK/ white -1000 ohms BCM in driver kick, white 16 pin plug (6), pin 4 Power Unlock (same as power lock) - Lock Motor yellow/black 5 wire BCM in driver kick, white 16 pin plug (7), pin 5 Driver Unlock Motor WHITE/ red 5 wire BCM in driver kick, white 16 pin plug (7), pin 6 Passenger Unlock Motor WHITE/ black 5 wire BCM in driver kick, white 16 pin plug (7), pin 7 Parking Lights (-) BLACK/ white - headlight switch, white 17 pin plug, pin 14 Parking Lights (+) RED / blue + BCM in driver kick, white 16 pin plug (8), pin 8 Hazards BLACK/ orange - BCM in driver kick, white 30 pin plug (3), pin 18 Turn Signal (Left) blue + BCM in driver kick, white 16 pin plug (8), pin 14 Turn Signal (Right) blue/black + BCM in driver kick, white 16 pin plug (8), pin 5 Headlight BLACK/ green - headlight switch, white 17 pin plug, pin 13 AutoLights BLACK/ pink (interrupt to turn off autolights) - headlight switch, white 17 pin plug, pin 12 Reverse Light GREEN/ black + BCM in driver kick, white 16 pin plug (7), pin 1 Left Front Door Trigger BLACK / YELLOW - N.C. BCM in driver kick, white 16 pin plug (8), pin 9 Right Front Door Trigger BLACK/ blue - N.C. BCM in driver kick, white 16 pin plug (8), pin 10 Left Rear Door Trigger BLACK / YELLOW - N.C. BCM in driver kick, white 16 pin plug (8), pin 12 Right Rear Door Trigger BLACK/ red - N.C. BCM in driver kick, white 16 pin plug (8), pin 11 Dome Supervision BLACK/ blue - BCM in driver kick, white 16 pin plug (6), pin 7 Trunk/Hatch Pin BLACK/ blue - BCM in driver kick, white 16 pin plug (6), pin 2 Rear Glass Pin N/A Hood Pin white - N.C. BCM in driver kick, black 24 pin plug (1), pin 10 Trunk/Hatch Release BLACK/ red - BCM in driver kick, white 30 pin plug (3), pin 28 Trunk Release Motor BLACK / YELLOW 5 wire BCM in driver kick, white 16 pin plug (7), pin 2 Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm black (driver door key lock) -1000 ohms BCM in driver kick, white 16 pin plug (6), pin 14 Factory Alarm Disarm (same as factory alarm arm) double - Disarm No Unlock (use keysense) (for factory keyless to func while remote started, use FAD instead) Trunk Alarm Shunt N/A Tachometer NOT red (I4) or blue (V6) ac any fuel injector Wait to Start N/A Neutral Safety BLACK/ green (M/T) - PCM under hood, driv rear corner, plg towards passenger side, pin 44 Clutch Pedal BLACK / YELLOW - clutch switch, white 2 pin plug, pin 1 Fuel Pump GREEN/ orange + driver kick, harness to rear Rear Defroster red - latched climate ctrl unit, wht 24 pin plug, pin 6 (manual A/C) or 10(auto A/C) Mirror Defroster (same as rear defroster) Left Front Heated Seat pink + resistor LH seat warmer switch, white 10 pin plug, pin 9 Right Front Heated Seat pink / YELLOW + resistor RH seat warmer switch, gray 10 pin plug, pin 9 Speed Sense white ac radio, white 24 pin plug, pin 17, or amp in pass kick, bk 16P plg, pin 9 Brake Wire RED / white + brake switch or driver kick, harness to rear Parking Brake BLACK/ red - BCM in driver kick, white 16 pin plug (8), pin 1 Horn Trigger black - BCM in driver kick, white 30 pin plug (3), pin 8 Wipers WHITE/ grn (low); WHITE/ blk (high); pink/org (ign) + wiper switch, black 14 pin plug, pins 4, 6, 3 Left Front Window (Up/Down) yellow/black - WHITE/ green A power window main switch, white 14 pin plug, pins 5 - 6, or 3 - 2 Right Front Window (Up/Down) ye/bk - wh/gn (w/auto); ye/pu - wh/pu (w/o auto) A pass pwr wndw sw, wht 12 pin plg, pins 11 - 7; driv kick, door harness Left Rear Window (Up/Down) blue/white - purple A driver kick, door harness Right Rear Window (Up/Down) blue - pink/blue A driver kick, door harness Sun Roof (Open/Close) gray/white - gray/black(function with ign on only) + sunroof switch, gray 6 pin plug, pins 5 - 6 Sun Roof (Limit/Close) N/A Memory Seat 1 gray/purple - position memory switch, white 5 pin plug, pin 3 Memory Seat 2 yellow - position memory switch, white 5 pin plug, pin 2 Memory Seat 3 blue/orange - position memory switch, white 5 pin plug, pin 1 Radio 12V ORANGE / black + radio, white 24 pin plug, pin 14 Radio Ground black - radio, white 24 pin plug, pin 24 Radio Ignition blue/black + radio, white 24 pin plug, pin 22 Radio Illumination ORANGE / black (parking lights); BROWN / yel (dimmer) +,- radio, white 24 pin plug, pins 15, 16 Factory Amp Turn-on WHITE/ green + radio, white 24 pin plug, pin 6 Power Antenna WHITE/ red (some models only) + radio, white 24 pin plug, pin 5 Left Front Speaker (+/-) WHITE/ black - gray/black or black - dk. green +,- radio, white 24 pin plug, pins 1 - 2 On models with amplifier, the speaker wires are WHITE/ black - gray/black at the amplifier in passenger kick, black 8 pin plug, pins 6 - 2. Right Front Speaker (+/-) WHITE/ red - gray/red or white - red +,- radio, white 24 pin plug, pins 3 - 4 On models with amplifier, the speaker wires are WHITE/ red - gray/red at the amplifier in passenger kick, black 8 pin plug, pins 7 - 3. Left Rear Speaker (+/-) WHITE/ purple - gray/white or black - dk. green +,- radio, white 24 pin plug, pins 10 - 11 On models with amplifier, the speaker wires are WHITE/ purple - gray/white at the amplifier in passenger kick, green 16 pin plug, pins 10 - 9. Right Rear Speaker (+/-) white - gray or white - red +,- radio, white 24 pin plug, pins 12 - 13 On models with amplifier, the speaker wires are white - gray at the amplifier in passenger kick, green 16 pin plug, pins 7 - 8. The rear surround speakers are wired in series, and the wires are WHITE/ red - gray/red at the amplifier, green 16 pin plug, pins 3 - 4. Center Channel (+/-) WHITE/ red - gray/red +,- amplifier in passenger kick, green 16 pin plug, pins 5 - 6 Subwoofer (+/-) WHITE/ black - gray/black +,- amplifier in passenger kick, black 8 pin plug, pins 8 - 4 Aux. Audio Input Left (+/-) red - BLACK/ white or black +,- radio, white 16 pin plug, pins 3 - 11, or 14 - 5 Aux. Audio Input Right (+/-) RED / white - BLACK/ white or black +,- radio, white 16 pin plug, pins 2 - 10, or 6 - 5 RSE Video (+/-) N/A RSE Audio Left (+/-) red - BLACK/ green or black (bluetooth/sat. audio) +,- radio, white 16 pin plug, pins 3 - 11, or 3 - 4 RSE Audio Right (+/-) RED / wht - blk/grn or black (bluetooth/sat. audio) +,- radio, white 16 pin plug, pins 2 - 10, or 2 - 4 Satellite Radio 12 Volts ORANGE / black + Sat Radio behind glove box, gry 16 pin plg, pin 16 Satellite Radio Ground black - Sat Radio behind glove box, gray 16 pin plg, pin 1 Satellite Radio Ignition blue/black + Sat Radio behind glove box, gray 16 pin plg, pin 8 Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) red - black +,- Satellite Radio, gray 16 pin plug, pins 3 - 4 Satellite Audio Right (+/-) RED / white - black +,- Satellite Radio, gray 16 pin plug, pins 2 - 4 Item Size Depth Location Headunit irregular center of dash Left Front Speaker 5.5 x 7.5 left front door Left Front Tweeter 1.2 left front door Right Front Speaker 5.5 x 7.5 right front door Right Front Tweeter 1.2 right front door Left Rear Speaker 5.5 x 7.5 left rear door Left Rear Tweeter 3.1 left rear deck (surround) Right Rear Speaker 5.5 x 7.5 right rear door Right Rear Tweeter 3.1 right rear deck (surround) Center Channel 3.1 top center of dash Subwoofer 9 center of rear deck Left Front Headrest Right Front Headrest Left Rear Headrest Right Rear Headrest Satellite Radio Tuner behind glove box ------------- Gary Sather |
