2010 buick lucerne
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137260
Printed Date: May 02, 2024 at 6:18 PM
Topic: 2010 buick lucerne
Posted By: jspec25
Subject: 2010 buick lucerne
Date Posted: September 15, 2014 at 9:20 AM
Need vehicle wiring for remote start.
Posted By: wirewise
Date Posted: September 15, 2014 at 12:32 PM
BUICK / LUCERNE / 2010 / Remote Start
12volts red + battery or rear fuse box under rear seat
Notes: If equipped, the Digital Radio Receiver is in the left side of the luggage compartment.
Starter purple (for starter kill only) + starter or underhood fuse box, black 56 pin plug, pin E2
Second Starter white +9.6K ohms ignition switch or BCM, green plug, pin 2
Notes: The BCM (Body Control Module) is under the passenger dash, above the passenger kick.
If interface module is not available, see Tech Doc 1605.
Ignition pink + ignition switch or BCM, green plug, pin 14
Second Ignition N/A
Third Ignition N/A
Accessory brown + ignition switch or BCM, green plug, pin 21
Second Accessory same as second starter +6.3K ohms
Keysense same as second starter
Power Lock use Directed interface module
Notes: If interface module is not available, see Tech Doc 1601.
The driver door lock/unlock motor wires are gray - tan (5 wire) at the driver window switch, brown 16 pin plug, pins 7 and 8.
The passenger door lock/unlock motor wires are lt. green - gray/black (5 wire) at the passenger window switch, brown 16 pin plug, pins 7 and 8.
The rear doors power lock/unlock wires are dk. blue/black (+) - lt. blue/white (-) at the BCM, gray plug, pins 7 and 9. The BCM (Body Control Module) is under the passenger dash, above the passenger kick.
Power Unlock see power lock
Notes: The rear fuse box is under the left rear seat.
Lock Motor gray 5 wire rear door harness or rear fuse box, lt. gray 68 pin plug, pin B9
Unlock Motor tan 5 wire driver window switch, brown 16 pin plug, pin 8
Parking Lights+ purple (L), BROWN / white (R) + passenger kick or rear fuse box, lt. gray 68 pin plug, pins E2 and C3
Parking Lights- lt. blue/tan - headlight switch or BCM, white plug, pin 8
Hazards tan - hazard switch or BCM, green plug, pin 19
Turn Signal(L) lt. blue/white (F); yellow (R) + BCM, brown plug, pins 4 and 1
Turn Signal(R) dk. blue/white (F); dk. green (R) + BCM, black plug, pin 5; brown plug, pin 2
Reverse Light lt. green + passenger kick or BCM, pink plug, pin 2
Door Trigger gray/black (ajar), BLACK/ tan (open) - driver window switch, brown 16 pin plug, pins 13 and 11
Dome Supervision gray/black + passenger kick or BCM, pink plug, pin 1
Trunk/Hatch Pin ORANGE / gray - passenger kick or BCM, pink plug, pin 12
Hood Pin pink/black - passenger kick or BCM, black plug, pin 17
Trunk/Hatch Release lt. blue - release switch or BCM, white plug, pin 10
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green (driver door key cylinder) double - driver window switch, brown 16 pin plug, pin 4
Disarm No Unlock Passkey and ignition
Tachometer NOT pink/black or pink/gray ac any fuel injector
Wait to start N/A
Brake Wire lt. blue (functions with ignition on only) + passenger kick or BCM, brown plug, pin 5
Parking Brake lt. blue/white - parking brake switch or BCM, brown plug, pin 16
Horn Trigger tan - horn switch or BCM, brown plug, pin 18
Memory Seat 1 tan +2.26Kohms driver window switch, lt. gray 14 pin plug, pin 5
Memory Seat 2 same as memory seat 1 +2.26Kohms
Memory Seat 3 N/A +2.26Kohms
------------- ~wirewise~
Posted By: jspec25
Date Posted: September 15, 2014 at 2:01 PM
ok, so just a resistor on the 2nd starter and 2nd acc. But what starter hooks up to the remote start? no starter kill/alarm, just aremote start with keyless and a xk09
