peugeot boxer 3 wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137710
Printed Date: April 29, 2024 at 2:06 AM
Topic: peugeot boxer 3 wiring diagram
Posted By: rbinuk
Subject: peugeot boxer 3 wiring diagram
Date Posted: November 16, 2014 at 5:26 PM
Hi, I am trying to install an alarm to a peugeot boxer 3 (2008) and I am stuck at the wiring central locking wiring, there are 5 wires going to the drivers door locking kit and I can only pick the locking trigger which is a negative trigger to the blue / YELLOW wire, can not find the unlocking trigger...the other 4 wires are brown, pink, , PURPLE / black, pink/white...
Posted By: howie ll
Date Posted: November 17, 2014 at 12:40 AM
What a manufacturer, changed the bloody system and wiring colours every 3 weeks.
Once locked try cutting that wire to see if it unlocks.
Otherwise, relays on the motor wires.
Last one I did was a remote start and security and I used a DB-ALL data module for most of the functions.
Posted By: rbinuk
Date Posted: November 17, 2014 at 9:33 AM
Hi howie II and thanks for the replay, will get to it trying cutting the wire after it locks tomorrow sometimes and also will try other possible options, do you know where the central locking module is hidden? I can also try to find out from that... I picked one negative trigger wire at the back of unlock button on the dashboard it is grey/black wire but when I try using that it doesn't work... also the 5 wires going to the locking mechanism in the door 2 of them BROWN AND PINK are thicker wires than the others the one locks the doors blue / YELLOW and other 3 are thinner wires so I am guessing same as the locking wire unlocking wire should be a thin one too... the wire function the unlocking button on the dash BLACK/ grey wire is also a thin one same size as the blue / YELLOW wire...the suspect one is the thin pink/white wire as i touch (-) to it the doest lock the central passenger door means not functioning but it unlocks both door when I touch a live wire to it (+) i can open and lock both doors as normal ...and as it stands it is not (-) or (+)... confusing :-) but will find it eventually.. :-)
Posted By: howie ll
Date Posted: November 17, 2014 at 2:54 PM
Now do you see why most pros run a mile from Peugeot/Citroen?
So bleeding illogical!
